NEO-M9N, SMA (Qwiic) stopped getting fix on satellites and position coordinates
It worked perfectly but for some unknown reason it suddenly stopped getting coordinates and I’m getting garbage numbers (negative). Also, I’m not getting the satellites fix. Tried with a different antenna, no luck. What could be the reason? What kind of info I can provide to debug this?
Please help! Thanks!
Thanks for reaching out to us on this.
There are MANY different reasons how this could’ve happened; I suggest resetting the module https://cdn.sparkfun.com/assets/5/d/7/8 … 14286_.pdf , re-flashing the firmware, and updating it…all per the instructions in their datasheet.
Hope this helps, and happy sparking!
TS-Russell:
Thanks, I updating firmware fixed the issue :!:
