Hi there:
I was excited to receive today the new SFE Lassen iQ Fat 16 Datalogger. Sadly, I haven’t had any luck getting it to work correctly. I’m trying to get it to write KML. Yes, I’ve read the data sheet and have changed the mode in GPSCONF.txt from normal to KML (mulitple times). I have reformatted the card to FAT16 (mulitple times). I have waited for up to 30 minutes in various locations to see if it’s simply a problem of the GPS not finding a lock (as the data sheet forewarns). Still no joy. The STAT1 light never comes on. All datafiles are empty.
Normal mode seems slightly more promising, with the STAT0 light flashing about once per second after the unit finds a lock. However, even after taking the unit down the street and around a few blocks, all the data in the text file is the same:
$GPVTG,N*30
$GPGGA,0,00,*66
$GPVTG,N*30
$GPGGA,0,00,*66
$GPVTG,N*30
$GPGGA,0,00,*66
etc. (although sometimes there’s an occaisional extra $ or other special character)
Could it be a defective unit?
Any other advice?
