Okay I’ve worked with 12v car electronics for a while and am used to the standard BOSCH relay but I’m working on a DIY project for my fish tank and ran into this question.
Do they make something like this?
Let’s say I have pins: 1,2,3, and 4. If I join pins 1 + 2, 3 and 4 will be connected. Ideally I want to run 120vAC to pin 3 and a water pump to pin 4.
I’m trying to make a auto top off system where when the water evaporates below a certain level (float switch) my setup will turn on a water pump to fill my tank back up until the float switch isn’t closed.
At first my design had a 5v DC power going through the float switch until it closed triggering a solid state relay for AC power to a external pump. But the more I thought about it I didn’t want to expose 5v DC to my fish tank setup and came to this question.
Thanks guys!
