Olimex AT91SAM7X256 board and SAM-BA
I have Olimex board.I want to upload software through SAM-BA.I connect via USB download, first done FLASH jumper procedure but after finish download nothing work. I can’t connect via serial to SAM-BA.Jumpers are in position for debug port but don’t see port.I use USB to RS232 adapter on my laptop.Can you explain me how programming with SAM-BA works.I can’t understand from manual.MCU is AT91SAM7X256.Thanks
Darko
I’m having the same issue. I plug in the usb cable, lights flash. I just don’t know how to upload code using SAM-BA.
Hi
Try this document:
http://www.utasker.com/docs/SAM7X/uTaskerV1-2_SAM7X.PDF (page 8/21)
It describes COM download but USB is same procedure.
Mark
http://www.uTasker.com
