Olimex - CS-E9302 serial problem
I have just bought an olimex CS-E9302 development board and I’m trying to get the connection between the serial port RS232_0 on the board and my serial port on my computer to work. All documentation I have read says that when you are connecting a null modem cabel between these two serial ports you will see redboot loading the linux on board. But everything I get is an empty hyperterminal screen. Does anyone know how to solve my problem?
I have tried with hyperterminal settings at: 57600 8N1. I have also tried with changing the TEST0 jumper on the board from 2-3 position to 1-2 postion.
When I connecting an ethernet cable to the board, it gets an IP address and I’m able to see the webpage the board provides. It is also possible to connect through the hyperterminal and instead of choosing COM1 take TCP/IP (Winsock) and then see the busybox prompt. But in this way i’m not able to see the redboot.
Why can’t I connect my board through a serial connection?
The problem is solved. It was something wrong with RS232 communication on the board, so I got a new one and that worked just fine.
