olimex easy web II
Now I work with the Olimex Easy Web II.
I connect the 12Vdc and the RJ45 to see the web page at 192.168.0.30.
The page is OK.
Two question:
1.- In the original Web Page, the MCU temperature indicator not change, it is near to 20ºC and value similar to the other indicator, the “A/D Converter Value Port P6.7” it is OK?
2.- In the original Andreas Dannenberg Software, I d’ont find the software for the display, relays, external eeprom and button. I think that this extension are from olimex. Would you please send my this extension?.
I will use the mspgcc compiler to reload my aplication in the easy web II.
Thanks.
  1. temp indicator doesn’t change as probably you didn’t attach anything to the analog inputs
  2. the software for all ‘extended’ hardware is supposed to be written by the developer for his specific application
  3. let us know how the gcc port is working when you are ready
Tsvetan
