Open Scale baud rate issues
When changing the baudrate for OpenScale USB, I accidentally typed 360400 instead of 230400 . Now the openscale just spitsout garbage at every speed I try. Is there anyway to reset it to factory defaults?
I also tried to use Putty and connected at 360400. Still got garbage
Please help!!!
Hi asrajan,
You’ll just need to reset it to the stock firmware with the Arduino IDE. [This section of the Hookup Guide covers upgrading the firmware but it’s essentially the same thing as restoring it so just follow the steps there and you should be able to restore the OpenScale back to normal functionality.
This should fix your issue but if you have any problems or questions about this process, let us know and we would be happy to help as much as we can.](https://learn.sparkfun.com/tutorials/openscale-applications-and-hookup-guide#upgrading-the-firmware)
