I have ordered sparkfun’s Openlog board and I am facing difficulties with it.
The ? command doesnt work.
The arduino sketch associated with it to run on other arduino devices doesnt work either.
I feel like I’m missing something over here. I went trough Github as well as the hook guide[and comments] but I couldn’t make it work. Please help me with it.
              Hello vspsasdal, and thanks for posting on the forum.
- The ? command doesnt work.
How long ago did you order your OpenLog? It’s possible you may have a version that didn’t support the firmware version command.
- The arduino sketch associated with it to run on other arduino devices doesnt work either.
Which sketch are you trying and what errors does it give you?
I received on Tuesday this week.
Im trying to run openlog read example with arduino Uno. The connections I made are as follows:
RXI of OpenLog to pin 2 on the Arduino
TXO to 3
GRN to 4
VCC to 5V
GND to GND
It doesn’t give any errors. It gets uploaded but i see no output on the sd card and I cant even interact with openlog.
              Can you send me a photo showing how you have everything connected and photos of the top and bottom of your OpenLog board?
              I got it working. I uninstalled arduino and installed it again. It started working.
