Hello I am Teun from the Netherlands and have a qustion about the Openlog. I did order 2 pieces and cannot get it working. I am using a display from Lascar electronics so not a arduino. If i read well after powering up there must be a Config.txt file on my Sd card. But the card keeps empty. I know my connections are oke because when i connect a HM10 bluetooth interface it is working ok. I did hook up the VCC, GND and the RX pin from the openlog but nothing happens. I do have 2 pieces by 1 the blue led go’s on and stay s on and the second one the led stays off. I did try a new sd card and did the FAT32.
Any help will be welcom.
Teun
