Execute:
D:\Program Files\openocd-r520\bin>openocd-pp.exe -d3 -f at91sam7_pp.cfg
Open On-Chip Debugger (2008-03-22 12:00 CET) svn: r520
URL: http://svn.berlios.de/svnroot/repos/openocd/trunk/
Debug: 5 0 command.c:375 command_run_line(): script at91sam7_pp.cfg
Debug: 6 0 configuration.c:87 open_file_from_path(): opened at91sam7_pp.cfg
Debug: 7 0 command.c:375 command_run_line(): telnet_port 4444
Debug: 8 0 command.c:375 command_run_line(): gdb_port 3333
Debug: 9 0 command.c:375 command_run_line(): gdb_memory_map enable
Debug: 10 0 command.c:375 command_run_line(): gdb_flash_program enable
Debug: 11 0 command.c:375 command_run_line(): interface parport
Debug: 12 0 command.c:375 command_run_line(): parport_port 0x378
Debug: 13 0 command.c:375 command_run_line(): parport_cable wiggler
Debug: 14 0 command.c:375 command_run_line(): jtag_speed 0
Debug: 15 0 command.c:375 command_run_line(): jtag_nsrst_delay 200
Debug: 16 0 command.c:375 command_run_line(): jtag_ntrst_delay 200
Debug: 17 0 command.c:375 command_run_line(): reset_config srst_only srst_pull
s_trst
Debug: 18 0 command.c:375 command_run_line(): jtag_device 4 0x1 0xf 0xe
Debug: 19 0 command.c:375 command_run_line(): daemon_startup reset
Debug: 20 0 command.c:375 command_run_line(): target arm7tdmi little run_and_i
nit 0 arm7tdmi
Debug: 21 0 command.c:375 command_run_line(): run_and_halt_time 0 30
Debug: 22 0 command.c:375 command_run_line(): target_script 0 reset at91sam7_p
p.script
Debug: 23 0 command.c:375 command_run_line(): working_area 0 0x00200000 0x4000
nobackup
Debug: 24 0 command.c:375 command_run_line(): flash bank at91sam7 0 0 0 0 0
Debug: 25 0 jtag.c:1466 jtag_init(): -
Debug: 26 0 parport.c:401 parport_init(): requesting privileges for parallel p
ort 0x378...
Debug: 27 0 parport.c:411 parport_init(): ...privileges granted
Debug: 28 0 parport.c:234 parport_reset(): trst: 0, srst: 0
Debug: 29 16 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG controll
er reset(tms or TRST)
Debug: 30 16 jtag.c:1235 jtag_reset_callback(): -
Debug: 31 16 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG controll
Debug: 32 16 jtag.c:1235 jtag_reset_callback(): -
Info: 33 16 jtag.c:1329 jtag_examine_chain(): JTAG device found: 0x3f0f0f0f (
Manufacturer: 0x787, Part: 0xf0f0, Version: 0x3)
Debug: 34 16 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG controll
Debug: 35 16 jtag.c:1235 jtag_reset_callback(): -
Debug: 36 16 openocd.c:114 main(): jtag init complete
Debug: 37 16 openocd.c:118 main(): target init complete
Debug: 38 16 openocd.c:122 main(): flash init complete
Debug: 39 16 openocd.c:126 main(): NAND init complete
Debug: 40 16 openocd.c:130 main(): pld init complete
Debug: 41 16 gdb_server.c:1965 gdb_init(): gdb service for target arm7tdmi at
port 3333
Debug: 42 16 arm7_9_common.c:740 arm7_9_assert_reset(): target->state: unknown
Debug: 43 16 jtag.c:937 jtag_add_reset(): SRST line asserted
Debug: 44 16 jtag.c:948 jtag_add_reset(): JTAG reset with tms instead of TRST
Debug: 45 16 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG controll
Debug: 46 16 jtag.c:1235 jtag_reset_callback(): -
Debug: 47 16 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG controll
Debug: 48 16 jtag.c:1235 jtag_reset_callback(): -
Warning: 49 32 jtag.c:902 jtag_add_reset(): requested reset would assert trst
Debug: 50 32 jtag.c:937 jtag_add_reset(): SRST line asserted
Debug: 51 32 jtag.c:948 jtag_add_reset(): JTAG reset with tms instead of TRST
Debug: 52 32 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG controll
Debug: 53 32 jtag.c:1235 jtag_reset_callback(): -
Debug: 54 32 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG controll
Debug: 55 32 jtag.c:1235 jtag_reset_callback(): -
Debug: 56 32 parport.c:234 parport_reset(): trst: 0, srst: 1
Debug: 57 47 parport.c:234 parport_reset(): trst: 0, srst: 1
Debug: 58 110 arm7_9_common.c:802 arm7_9_deassert_reset(): target->state: rese
t
Debug: 59 110 jtag.c:941 jtag_add_reset(): SRST line released
Debug: 60 110 jtag.c:969 jtag_add_reset(): Now in TAP_TLR - Test-Logic-Reset(e
ither due to TRST line asserted or tms reset)
Debug: 61 110 parport.c:234 parport_reset(): trst: 0, srst: 0
Debug: 62 516 arm7_9_common.c:968 arm7_9_halt(): target->state: running
Debug: 63 516 embeddedice.c:376 embeddedice_write_reg(): 9: 0xffffffff
Debug: 64 516 embeddedice.c:376 embeddedice_write_reg(): 11: 0xffffffff
Debug: 65 516 embeddedice.c:376 embeddedice_write_reg(): 12: 0x00000100
Debug: 66 516 embeddedice.c:376 embeddedice_write_reg(): 13: 0x000000f7
Debug: 67 516 arm7_9_common.c:700 arm7_9_poll(): DBGACK set, dbg_state->value:
0x9
Debug: 68 516 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 69 516 embeddedice.c:376 embeddedice_write_reg(): 12: 0x00000000
Debug: 70 516 arm7_9_common.c:1086 arm7_9_debug_entry(): target entered debug
from ARM state
Debug: 71 532 arm7_9_common.c:1118 arm7_9_debug_entry(): target entered debug
state in Supervisor mode
Debug: 72 532 arm7_9_common.c:1147 arm7_9_debug_entry(): r0: 0x10000000
Debug: 73 532 arm7_9_common.c:1147 arm7_9_debug_entry(): r1: 0x00000800
Debug: 74 532 arm7_9_common.c:1147 arm7_9_debug_entry(): r2: 0x00000800
Debug: 75 532 arm7_9_common.c:1147 arm7_9_debug_entry(): r3: 0x00000800
Debug: 76 532 arm7_9_common.c:1147 arm7_9_debug_entry(): r4: 0x00000000
Debug: 77 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r5: 0x00000100
Debug: 78 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r6: 0x2d4a03a5
Debug: 79 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r7: 0xd61000e1
Debug: 80 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r8: 0x47cec6bc
Debug: 81 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r9: 0xf72bfa59
Debug: 82 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r10: 0x47daeeb2
Debug: 83 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r11: 0xff3dfa2f
Debug: 84 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r12: 0x0001d4c0
Debug: 85 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r13: 0x00200ff0
Debug: 86 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r14: 0x00200418
Debug: 87 547 arm7_9_common.c:1147 arm7_9_debug_entry(): r15: 0x0000b0c4
Debug: 88 563 arm7_9_common.c:1153 arm7_9_debug_entry(): entered debug state a
t PC 0xb0c4
Debug: 89 563 target.c:566 target_call_event_callbacks(): target event 0
Debug: 90 563 configuration.c:87 open_file_from_path(): opened at91sam7_pp.scr
ipt
Info: 91 563 target.c:240 target_init_handler(): executing reset script 'at91
sam7_pp.script'
Debug: 92 563 command.c:375 command_run_line(): mww 0xffffff60 0x00310200
Debug: 93 563 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 94 578 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 95 578 command.c:375 command_run_line(): mww 0xffffff70 0x00310200
Debug: 96 578 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 97 578 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 98 578 command.c:375 command_run_line(): sleep 10
Debug: 99 594 command.c:375 command_run_line(): wait_halt
Debug: 100 594 arm7_9_common.c:700 arm7_9_poll(): DBGACK set, dbg_state->value
: 0x9
Debug: 101 594 command.c:375 command_run_line(): flash erase_sector 0 0 31
Debug: 102 594 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffff240,
size: 0x00000004, count: 0x00000001
Debug: 103 703 target.c:960 target_read_u32(): address: 0xfffff240, value: 0x2
72a0a40
Debug: 104 703 at91sam7.c:366 at91sam7_read_part_info(): nvptyp: 0x002, arch:
0x0072
Debug: 105 703 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffffc24,
Debug: 106 813 target.c:960 target_read_u32(): address: 0xfffffc24, value: 0x0
0000000
Debug: 107 813 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffffc30,
Debug: 108 813 target.c:960 target_read_u32(): address: 0xfffffc30, value: 0x0
0000000
Debug: 109 813 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffffc2c,
Debug: 110 938 target.c:960 target_read_u32(): address: 0xfffffc2c, value: 0x0
0003f00
Debug: 111 938 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68,
Debug: 112 1047 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 113 1047 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
, size: 0x00000004, count: 0x00000001
Debug: 114 1157 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Warning: 115 1157 at91sam7.c:646 at91sam7_erase(): Sector numbers based on lockb
it count, probably a deprecated script
Debug: 116 1157 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffffc24
Debug: 117 1266 target.c:960 target_read_u32(): address: 0xfffffc24, value: 0x
00000000
Debug: 118 1266 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffffc30
Debug: 119 1375 target.c:960 target_read_u32(): address: 0xfffffc30, value: 0x
00000000
Debug: 120 1375 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffffc2c
Debug: 121 1485 target.c:960 target_read_u32(): address: 0xfffffc2c, value: 0x
00003f00
Debug: 122 1485 at91sam7.c:246 at91sam7_set_flash_mode(): fmcn[0]: 0
Debug: 123 1485 target.c:1013 target_write_u32(): address: 0xffffff60, value:
0x00000000
Debug: 124 1485 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 125 1485 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 126 1500 target.c:1013 target_write_u32(): address: 0xffffff64, value:
0x5a000008
Debug: 127 1500 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 128 1500 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 129 1500 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0008, flashplane: 0, pagenumber:0
Debug: 130 1500 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 131 1516 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000400
Debug: 132 1516 at91sam7.c:260 at91sam7_wait_status_busy(): status[0]: 0x400
Debug: 133 1532 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 134 1532 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 135 1532 at91sam7.c:264 at91sam7_wait_status_busy(): status[0]: 0x401
Debug: 136 1532 at91sam7.c:246 at91sam7_set_flash_mode(): fmcn[1]: 0
Debug: 137 1532 target.c:1013 target_write_u32(): address: 0xffffff70, value:
0x00000000
Debug: 138 1532 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 139 1547 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 140 1547 target.c:1013 target_write_u32(): address: 0xffffff74, value:
0x5a000008
Debug: 141 1547 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 142 1547 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 143 1563 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0008, flashplane: 1, pagenumber:0
Debug: 144 1563 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff78
Debug: 145 1563 target.c:960 target_read_u32(): address: 0xffffff78, value: 0x
00000000
Debug: 146 1563 at91sam7.c:260 at91sam7_wait_status_busy(): status[1]: 0x0
Debug: 147 1578 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff78
Debug: 148 1578 target.c:960 target_read_u32(): address: 0xffffff78, value: 0x
00000001
Debug: 149 1578 at91sam7.c:264 at91sam7_wait_status_busy(): status[1]: 0x1
Info: 150 1578 options.c:50 configuration_output_handler(): erased sectors 0
through 31 on flash bank 0 in 0.421875s
Debug: 151 1578 command.c:375 command_run_line(): flash write_bank 0 c:/tmp/oo
cdfsh.bin 0x0
Debug: 152 1594 configuration.c:87 open_file_from_path(): opened c:/tmp/oocdfs
h.bin
Debug: 153 1594 at91sam7.c:751 at91sam7_write(): first_page: 0, last_page: 8,
count 2048
Debug: 154 1594 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffffc24
Debug: 155 1594 target.c:960 target_read_u32(): address: 0xfffffc24, value: 0x
00000000
Debug: 156 1610 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffffc30
Debug: 157 1610 target.c:960 target_read_u32(): address: 0xfffffc30, value: 0x
00000000
Debug: 158 1610 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xfffffc2c
Debug: 159 1610 target.c:960 target_read_u32(): address: 0xfffffc2c, value: 0x
00003f00
Debug: 160 1625 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 161 2172 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 162 2172 at91sam7.c:246 at91sam7_set_flash_mode(): fmcn[0]: 0
Debug: 163 2172 target.c:1013 target_write_u32(): address: 0xffffff60, value:
0x00000000
Debug: 164 2172 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 165 2172 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 166 2172 target.c:1013 target_write_u32(): address: 0xffffff64, value:
0x5a000001
Debug: 167 2188 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 168 2188 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 169 2188 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0001, flashplane: 0, pagenumber:0
Debug: 170 2188 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 171 2203 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 172 2203 at91sam7.c:264 at91sam7_wait_status_busy(): status[0]: 0x401
Debug: 173 2203 at91sam7.c:776 at91sam7_write(): Write flash plane:0 page numb
er:0
Debug: 174 2203 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 175 2750 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 176 2750 target.c:1013 target_write_u32(): address: 0xffffff64, value:
0x5a000101
Debug: 177 2750 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 178 2750 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 179 2750 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0101, flashplane: 0, pagenumber:1
Debug: 180 2750 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 181 2766 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 182 2766 at91sam7.c:264 at91sam7_wait_status_busy(): status[0]: 0x401
Debug: 183 2766 at91sam7.c:776 at91sam7_write(): Write flash plane:0 page numb
er:1
Debug: 184 2766 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 185 3328 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 186 3328 target.c:1013 target_write_u32(): address: 0xffffff64, value:
0x5a000201
Debug: 187 3328 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 188 3328 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 189 3328 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0201, flashplane: 0, pagenumber:2
Debug: 190 3328 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 191 3344 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 192 3344 at91sam7.c:264 at91sam7_wait_status_busy(): status[0]: 0x401
Debug: 193 3344 at91sam7.c:776 at91sam7_write(): Write flash plane:0 page numb
er:2
Debug: 194 3344 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 195 3907 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 196 3907 target.c:1013 target_write_u32(): address: 0xffffff64, value:
0x5a000301
Debug: 197 3907 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 198 3907 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 199 3907 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0301, flashplane: 0, pagenumber:3
Debug: 200 3907 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 201 3922 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 202 3922 at91sam7.c:264 at91sam7_wait_status_busy(): status[0]: 0x401
Debug: 203 3922 at91sam7.c:776 at91sam7_write(): Write flash plane:0 page numb
er:3
Debug: 204 3922 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 205 4485 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 206 4485 target.c:1013 target_write_u32(): address: 0xffffff64, value:
0x5a000401
Debug: 207 4485 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 208 4485 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 209 4485 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0401, flashplane: 0, pagenumber:4
Debug: 210 4485 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 211 4500 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 212 4500 at91sam7.c:264 at91sam7_wait_status_busy(): status[0]: 0x401
Debug: 213 4500 at91sam7.c:776 at91sam7_write(): Write flash plane:0 page numb
er:4
Debug: 214 4500 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 215 5063 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 216 5063 target.c:1013 target_write_u32(): address: 0xffffff64, value:
0x5a000501
Debug: 217 5063 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 218 5063 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 219 5078 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0501, flashplane: 0, pagenumber:5
Debug: 220 5078 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 221 5078 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 222 5078 at91sam7.c:264 at91sam7_wait_status_busy(): status[0]: 0x401
Debug: 223 5078 at91sam7.c:776 at91sam7_write(): Write flash plane:0 page numb
er:5
Debug: 224 5094 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 225 5641 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 226 5641 target.c:1013 target_write_u32(): address: 0xffffff64, value:
0x5a000601
Debug: 227 5641 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 228 5641 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 229 5641 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0601, flashplane: 0, pagenumber:6
Debug: 230 5657 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 231 5657 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 232 5657 at91sam7.c:264 at91sam7_wait_status_busy(): status[0]: 0x401
Debug: 233 5657 at91sam7.c:776 at91sam7_write(): Write flash plane:0 page numb
er:6
Debug: 234 5657 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 235 6219 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 236 6219 target.c:1013 target_write_u32(): address: 0xffffff64, value:
0x5a000701
Debug: 237 6219 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000004
Debug: 238 6219 embeddedice.c:376 embeddedice_write_reg(): 0: 0x00000005
Debug: 239 6219 at91sam7.c:290 at91sam7_flash_command(): Flash command: 0x5a00
0701, flashplane: 0, pagenumber:7
Debug: 240 6219 arm7_9_common.c:1821 arm7_9_read_memory(): address: 0xffffff68
Debug: 241 6235 target.c:960 target_read_u32(): address: 0xffffff68, value: 0x
00000401
Debug: 242 6235 at91sam7.c:264 at91sam7_wait_status_busy(): status[0]: 0x401
Debug: 243 6235 at91sam7.c:776 at91sam7_write(): Write flash plane:0 page numb
er:7
Debug: 244 6235 command.c:375 command_run_line(): reset run
Debug: 245 6235 target.c:1640 handle_reset_command(): -
Debug: 246 6250 arm7_9_common.c:740 arm7_9_assert_reset(): target->state: halt
ed
Debug: 247 6250 jtag.c:937 jtag_add_reset(): SRST line asserted
Debug: 248 6250 jtag.c:948 jtag_add_reset(): JTAG reset with tms instead of TR
ST
Debug: 249 6250 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG contr
oller reset(tms or TRST)
Debug: 250 6250 jtag.c:1235 jtag_reset_callback(): -
Debug: 251 6250 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG contr
Debug: 252 6250 jtag.c:1235 jtag_reset_callback(): -
Warning: 253 6250 jtag.c:902 jtag_add_reset(): requested reset would assert trst
Debug: 254 6266 jtag.c:937 jtag_add_reset(): SRST line asserted
Debug: 255 6266 jtag.c:948 jtag_add_reset(): JTAG reset with tms instead of TR
ST
Debug: 256 6266 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG contr
Debug: 257 6266 jtag.c:1235 jtag_reset_callback(): -
Debug: 258 6266 jtag.c:305 jtag_call_event_callbacks(): jtag event: JTAG contr
Debug: 259 6266 jtag.c:1235 jtag_reset_callback(): -
Debug: 260 6266 parport.c:234 parport_reset(): trst: 0, srst: 1
Debug: 261 6297 parport.c:234 parport_reset(): trst: 0, srst: 1
Debug: 262 6360 arm7_9_common.c:802 arm7_9_deassert_reset(): target->state: re
set
Debug: 263 6360 jtag.c:941 jtag_add_reset(): SRST line released
Debug: 264 6360 jtag.c:969 jtag_add_reset(): Now in TAP_TLR - Test-Logic-Reset
(either due to TRST line asserted or tms reset)
Debug: 265 6360 parport.c:234 parport_reset(): trst: 0, srst: 0
Debug: 266 6766 command.c:375 command_run_line(): shutdown
Warning: 267 6766 arm7_9_common.c:724 arm7_9_poll(): DBGACK set, but the target
did not end up in the halted stated 1
User: 269 7266 target.c:365 target_process_reset(): Timed out waiting for res
et
Debug: 270 7266 openocd.c:142 main(): target init reset complete
