OpenOCDv0.4.0 Error ft2232_read():couldn't read enough bytes
I am trying to upgrade to OpenOCD 0.4.0, using ftd2xx drivers, olimex arm-usb-tiny,stm-h103. OpenOCD seems to be working ok until ft2232 read is attempted
Error: 573 66190 ft2232.c:438 ft2232_read(): couldn’t read enough bytes from FT2232 device (0 < 6)
(Platform; Eclipse Galileo, Cygwin ,Windows7 64 bit) Note that programming worked ok, no errors with older versions.
There are lots of posts regarding libftdi-1.0 in relation to read errors on ft2232. I have not been able to work out how all this relates to the current version of OpenOCD etc
Can anyone advise what the current status is ? How do these various versions/drivers relate…libftdi, libusb, libftd2xx
Full log is as follows;
Open On-Chip Debugger 0.4.0 (2010-06-25-11:18)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
User : 10 0 command.c:539 command_print(): debug_level: 3
Debug: 11 0 configuration.c:45 add_script_search_dir(): adding C:\Eclipse\openocd\src..
Debug: 12 0 configuration.c:45 add_script_search_dir(): adding C:/Eclipse/openocd/src/…/share/openocd/scripts
Debug: 13 0 configuration.c:87 find_file(): found olimex-jtag-tiny.cfg
Debug: 14 0 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_interface ft2232
Debug: 15 0 command.c:133 script_debug(): command - interface ocd_interface ft2232
Debug: 17 0 command.c:346 register_command_handler(): registering ‘ocd_ft2232_device_desc’…
Debug: 18 0 command.c:346 register_command_handler(): registering ‘ocd_ft2232_serial’…
Debug: 19 0 command.c:346 register_command_handler(): registering ‘ocd_ft2232_layout’…
Debug: 20 0 command.c:346 register_command_handler(): registering ‘ocd_ft2232_vid_pid’…
Debug: 21 0 command.c:346 register_command_handler(): registering ‘ocd_ft2232_latency’…
Debug: 22 0 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_ft2232_device_desc Olimex OpenOCD JTAG TINY
Debug: 23 0 command.c:133 script_debug(): command - ft2232_device_desc ocd_ft2232_device_desc Olimex OpenOCD JTAG TINY
Debug: 25 0 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_ft2232_layout olimex-jtag
Debug: 26 0 command.c:133 script_debug(): command - ft2232_layout ocd_ft2232_layout olimex-jtag
Debug: 28 0 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_ft2232_vid_pid 0x15ba 0x0004
Debug: 29 0 command.c:133 script_debug(): command - ft2232_vid_pid ocd_ft2232_vid_pid 0x15ba 0x0004
Debug: 31 0 configuration.c:87 find_file(): found olimex_stm32_h103.cfg
Debug: 32 0 configuration.c:87 find_file(): found target/stm32.cfg
Debug: 33 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag_khz 10
Debug: 34 16 command.c:133 script_debug(): command - jtag_khz ocd_jtag_khz 10
Debug: 36 16 core.c:1560 jtag_config_khz(): handle jtag khz
Debug: 37 16 core.c:1523 jtag_khz_to_speed(): convert khz to interface specific speed value
User : 38 16 command.c:539 command_print(): 10 kHz
Debug: 39 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag_nsrst_delay 100
Debug: 40 16 command.c:133 script_debug(): command - jtag_nsrst_delay ocd_jtag_nsrst_delay 100
User : 42 16 command.c:539 command_print(): jtag_nsrst_delay: 100
Debug: 43 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag_ntrst_delay 100
Debug: 44 16 command.c:133 script_debug(): command - jtag_ntrst_delay ocd_jtag_ntrst_delay 100
User : 46 16 command.c:539 command_print(): jtag_ntrst_delay: 100
Debug: 47 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag newtap stm32 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x3ba00477
Debug: 48 16 command.c:133 script_debug(): command - ocd_jtag ocd_jtag newtap stm32 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x3ba00477
Debug: 49 16 tcl.c:568 jim_newtap_cmd(): Creating New Tap, Chip: stm32, Tap: cpu, Dotted: stm32.cpu, 8 params
Debug: 50 16 tcl.c:585 jim_newtap_cmd(): Processing option: -irlen
Debug: 51 16 tcl.c:585 jim_newtap_cmd(): Processing option: -ircapture
Debug: 52 16 tcl.c:585 jim_newtap_cmd(): Processing option: -irmask
Debug: 53 16 tcl.c:585 jim_newtap_cmd(): Processing option: -expected-id
Debug: 54 16 core.c:1300 jtag_tap_init(): Created Tap: stm32.cpu @ abs position 0, irlen 4, capture: 0x1 mask: 0xf
Debug: 55 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag newtap stm32 bs -irlen 5 -expected-id 0x16410041
Debug: 56 16 command.c:133 script_debug(): command - ocd_jtag ocd_jtag newtap stm32 bs -irlen 5 -expected-id 0x16410041
Debug: 57 16 tcl.c:568 jim_newtap_cmd(): Creating New Tap, Chip: stm32, Tap: bs, Dotted: stm32.bs, 4 params
Debug: 58 16 tcl.c:585 jim_newtap_cmd(): Processing option: -irlen
Debug: 59 16 tcl.c:585 jim_newtap_cmd(): Processing option: -expected-id
Debug: 60 16 core.c:1300 jtag_tap_init(): Created Tap: stm32.bs @ abs position 0, irlen 5, capture: 0x1 mask: 0x3
Debug: 61 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_target create stm32.cpu cortex_m3 -endian little -chain-position stm32.cpu
Debug: 62 16 command.c:133 script_debug(): command - ocd_target ocd_target create stm32.cpu cortex_m3 -endian little -chain-position stm32.cpu
Debug: 63 16 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 64 16 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 65 16 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 66 16 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 67 16 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 68 16 command.c:346 register_command_handler(): registering ‘ocd_cortex_m3’…
Debug: 69 16 command.c:346 register_command_handler(): registering ‘ocd_cortex_m3’…
Debug: 70 16 command.c:346 register_command_handler(): registering ‘ocd_cortex_m3’…
Debug: 71 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 72 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 73 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 74 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 75 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 76 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 77 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 78 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 79 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 80 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 81 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 82 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 83 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 84 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 85 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 86 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 87 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 88 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 89 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 90 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 91 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 92 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 93 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 94 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 95 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 96 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 97 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 98 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 99 16 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 100 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu configure -work-area-phys 0x20000000 -work-area-size 0x5000 -work-area-backup 0
Debug: 101 16 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu configure -work-area-phys 0x20000000 -work-area-size 0x5000 -work-area-backup 0
Debug: 102 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_flash bank stm32.flash stm32x 0 0 0 0 stm32.cpu
Debug: 103 16 command.c:133 script_debug(): command - ocd_flash ocd_flash bank stm32.flash stm32x 0 0 0 0 stm32.cpu
Debug: 105 16 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 106 16 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 107 16 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 108 16 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 109 16 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 110 16 httpd_stubs.c:28 httpd_start(): libocdserver was built without HTTPD support
Debug: 111 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_init
Debug: 112 16 command.c:133 script_debug(): command - init ocd_init
Debug: 114 16 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_target init
Debug: 115 16 command.c:133 script_debug(): command - ocd_target ocd_target init
Debug: 117 16 target.c:835 handle_target_init_command(): Initializing targets…
Debug: 118 16 command.c:346 register_command_handler(): registering ‘ocd_target_request’…
Debug: 119 16 command.c:346 register_command_handler(): registering ‘ocd_trace’…
Debug: 120 16 command.c:346 register_command_handler(): registering ‘ocd_trace’…
Debug: 121 16 command.c:346 register_command_handler(): registering ‘ocd_fast_load_image’…
Debug: 122 16 command.c:346 register_command_handler(): registering ‘ocd_fast_load’…
Debug: 123 16 command.c:346 register_command_handler(): registering ‘ocd_profile’…
Debug: 124 16 command.c:346 register_command_handler(): registering ‘ocd_virt2phys’…
Debug: 125 16 command.c:346 register_command_handler(): registering ‘ocd_reg’…
Debug: 126 16 command.c:346 register_command_handler(): registering ‘ocd_poll’…
Debug: 127 16 command.c:346 register_command_handler(): registering ‘ocd_wait_halt’…
Debug: 128 16 command.c:346 register_command_handler(): registering ‘ocd_halt’…
Debug: 129 16 command.c:346 register_command_handler(): registering ‘ocd_resume’…
Debug: 130 16 command.c:346 register_command_handler(): registering ‘ocd_reset’…
Debug: 131 16 command.c:346 register_command_handler(): registering ‘ocd_soft_reset_halt’…
Debug: 132 16 command.c:346 register_command_handler(): registering ‘ocd_step’…
Debug: 133 16 command.c:346 register_command_handler(): registering ‘ocd_mdw’…
Debug: 134 16 command.c:346 register_command_handler(): registering ‘ocd_mdh’…
Debug: 135 16 command.c:346 register_command_handler(): registering ‘ocd_mdb’…
Debug: 136 16 command.c:346 register_command_handler(): registering ‘ocd_mww’…
Debug: 137 16 command.c:346 register_command_handler(): registering ‘ocd_mwh’…
Debug: 138 16 command.c:346 register_command_handler(): registering ‘ocd_mwb’…
Debug: 139 16 command.c:346 register_command_handler(): registering ‘ocd_bp’…
Debug: 140 16 command.c:346 register_command_handler(): registering ‘ocd_rbp’…
Debug: 141 16 command.c:346 register_command_handler(): registering ‘ocd_wp’…
Debug: 142 16 command.c:346 register_command_handler(): registering ‘ocd_rwp’…
Debug: 143 16 command.c:346 register_command_handler(): registering ‘ocd_load_image’…
Debug: 144 16 command.c:346 register_command_handler(): registering ‘ocd_dump_image’…
Debug: 145 16 command.c:346 register_command_handler(): registering ‘ocd_verify_image’…
Debug: 146 16 command.c:346 register_command_handler(): registering ‘ocd_test_image’…
Debug: 147 16 command.c:346 register_command_handler(): registering ‘ocd_reset_nag’…
Debug: 148 16 ft2232.c:2097 ft2232_init(): ft2232 interface using shortest path jtag state transitions
Debug: 149 16 ft2232.c:1843 ft2232_init_ftd2xx(): ‘ft2232’ interface using FTD2XX with ‘olimex-jtag’ layout (15ba:0004)
Debug: 150 78 ft2232.c:1954 ft2232_init_ftd2xx(): current latency timer: 2
Info : 151 78 ft2232.c:1981 ft2232_init_ftd2xx(): device: 4 “2232C”
Info : 152 78 ft2232.c:1982 ft2232_init_ftd2xx(): deviceID: 364511236
Info : 153 78 ft2232.c:1983 ft2232_init_ftd2xx(): SerialNumber: FTS932G7A
Info : 154 78 ft2232.c:1984 ft2232_init_ftd2xx(): Description: Olimex OpenOCD JTAG TINY A
Debug: 155 78 ft2232.c:2443 olimex_jtag_init(): 80 08 1b
Debug: 156 94 ft2232.c:2487 olimex_jtag_init(): 82 09 0f
Debug: 157 94 core.c:1523 jtag_khz_to_speed(): convert khz to interface specific speed value
Debug: 158 94 core.c:1527 jtag_khz_to_speed(): have interface set up
Debug: 159 94 ft2232.c:523 ft2232_speed(): 86 57 02
Debug: 160 109 core.c:1523 jtag_khz_to_speed(): convert khz to interface specific speed value
Debug: 161 109 core.c:1527 jtag_khz_to_speed(): have interface set up
Info : 162 109 core.c:1350 jtag_interface_init(): clock speed 10 kHz
Debug: 163 109 openocd.c:122 handle_init_command(): jtag interface init complete
Debug: 164 109 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag init
Debug: 165 109 command.c:133 script_debug(): command - ocd_jtag ocd_jtag init
Debug: 167 109 tcl.c:854 handle_jtag_init_command(): Initializing jtag devices…
Debug: 168 109 ft2232.c:1361 olimex_jtag_reset(): trst: 0, srst: 0, high_output: 0x01, high_direction: 0x0f
Debug: 169 109 core.c:672 jtag_add_reset(): SRST line released
Debug: 170 109 core.c:697 jtag_add_reset(): TRST line released
Debug: 171 109 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 172 421 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init
Debug: 173 421 command.c:133 script_debug(): command - ocd_jtag ocd_jtag arp_init
Debug: 174 421 core.c:1364 jtag_init_inner(): Init JTAG chain
Debug: 175 421 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 176 421 core.c:1017 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS
Debug: 177 421 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 178 484 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : 179 484 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Debug: 180 484 core.c:1182 jtag_validate_ircapture(): IR capture validation scan
Debug: 181 484 core.c:1243 jtag_validate_ircapture(): stm32.cpu: IR capture 0x01
Debug: 182 484 core.c:1243 jtag_validate_ircapture(): stm32.bs: IR capture 0x01
Debug: 183 484 openocd.c:132 handle_init_command(): Examining targets…
Debug: 184 484 arm_adi_v5.c:1204 ahbap_debugport_init():
Debug: 185 593 arm_adi_v5.c:1265 ahbap_debugport_init(): MEM-AP #0 ID Register 0x14770011, Debug ROM Address 0xe00ff003
Debug: 186 624 target.c:1488 target_read_u32(): address: 0xe000ed00, value: 0x411fc231
Debug: 187 624 cortex_m3.c:1694 cortex_m3_examine(): Cortex-M3 r1p1 processor detected
Debug: 188 624 cortex_m3.c:1695 cortex_m3_examine(): cpuid: 0x411fc231
Debug: 189 655 target.c:1488 target_read_u32(): address: 0xe0002000, value: 0x00000260
Debug: 190 655 cortex_m3.c:1712 cortex_m3_examine(): FPB fpcr 0x260, numcode 6, numlit 2
Debug: 191 686 target.c:1488 target_read_u32(): address: 0xe0001000, value: 0x40000000
Debug: 192 686 cortex_m3.c:1664 cortex_m3_dwt_setup(): DWT dwtcr 0x40000000, comp 4, watch/trigger
Info : 193 686 cortex_m3.c:1721 cortex_m3_examine(): stm32.cpu: hardware has 6 breakpoints, 4 watchpoints
Debug: 194 686 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_flash init
Debug: 195 686 command.c:133 script_debug(): command - ocd_flash ocd_flash init
Warn : 197 733 cortex_m3.c:426 cortex_m3_poll(): stm32.cpu – clearing lockup after double fault
Debug: 199 764 tcl.c:920 handle_flash_init_command(): Initializing flash devices…
Debug: 200 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 201 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 202 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 203 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 204 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 205 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 206 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 207 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 208 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 209 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 210 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 211 764 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 212 764 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_mflash init
Debug: 213 764 command.c:133 script_debug(): command - ocd_mflash ocd_mflash init
Debug: 215 796 mflash.c:1325 handle_mflash_init_command(): Initializing mflash devices…
Debug: 216 796 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_nand init
Debug: 217 796 command.c:133 script_debug(): command - ocd_nand ocd_nand init
Debug: 219 811 tcl.c:536 handle_nand_init_command(): Initializing NAND devices…
Debug: 220 811 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_pld init
Debug: 221 811 command.c:133 script_debug(): command - ocd_pld ocd_pld init
Debug: 223 842 pld.c:231 handle_pld_init_command(): Initializing PLDs…
Debug: 224 842 gdb_server.c:2370 gdb_target_start(): gdb service for target ‘stm32.cpu’ on TCP port 3333
Info : 225 24211 server.c:81 add_connection(): accepting ‘gdb’ connection from 0
Debug: 226 24211 breakpoints.c:161 breakpoint_clear_target(): Delete all breakpoints for target: stm32.cpu
Debug: 227 24211 breakpoints.c:299 watchpoint_clear_target(): Delete all watchpoints for target: stm32.cpu
Debug: 228 24211 target.c:968 target_call_event_callbacks(): target event 25 (gdb-attach)
Debug: 229 24211 gdb_server.c:856 gdb_new_connection(): New GDB Connection: 1, Target stm32.cpu, state: halted
Debug: 230 24211 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qSupported’
Warn : 231 24211 gdb_server.c:649 gdb_get_packet_inner(): acknowledgment received, but no packet pending
Debug: 232 24211 gdb_server.c:2147 gdb_input_inner(): received packet: ‘?’
Debug: 233 24211 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc-1’
Debug: 234 24227 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qC’
Debug: 235 24227 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qOffsets’
Debug: 236 24227 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hg0’
Debug: 237 24227 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 238 24227 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qXfer:memory-map:read::0,fff’
Debug: 239 24259 target.c:1488 target_read_u32(): address: 0xe0042000, value: 0x20016410
Info : 240 24259 stm32x.c:678 stm32x_probe(): device id = 0x20016410
Debug: 241 24290 target.c:1516 target_read_u16(): address: 0x1ffff7e0, value: 0x0080
Info : 242 24290 stm32x.c:753 stm32x_probe(): flash size = 128kbytes
Debug: 243 24322 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m0,4’
Debug: 244 24322 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x00000000, len: 0x00000004
Debug: 245 24322 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x00000000
Debug: 246 24353 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qSymbol::’
Debug: 247 24431 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m0,4’
Debug: 248 24431 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x00000000, len: 0x00000004
Debug: 249 24431 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x00000000
Debug: 250 24540 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,726573657420696e6974’
Debug: 251 24556 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_reset init
Debug: 252 24556 command.c:133 script_debug(): command - reset ocd_reset init
Debug: 254 24587 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_target names
Debug: 255 24587 command.c:133 script_debug(): command - ocd_target ocd_target names
Debug: 256 24587 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-start
Debug: 257 24587 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-start
Debug: 258 24587 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init-reset
Debug: 259 24587 command.c:133 script_debug(): command - ocd_jtag ocd_jtag arp_init-reset
Debug: 260 24587 core.c:1451 jtag_init_reset(): Initializing with hard TRST+SRST reset
Debug: 261 24587 core.c:685 jtag_add_reset(): JTAG reset with TLR instead of TRST
Debug: 262 24587 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 263 24587 core.c:1364 jtag_init_inner(): Init JTAG chain
Debug: 264 24587 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 265 24587 core.c:1017 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS
Debug: 266 24587 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 267 24649 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : 268 24649 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Debug: 269 24649 core.c:1182 jtag_validate_ircapture(): IR capture validation scan
Debug: 270 24649 core.c:1243 jtag_validate_ircapture(): stm32.cpu: IR capture 0x01
Debug: 271 24649 core.c:1243 jtag_validate_ircapture(): stm32.bs: IR capture 0x01
Debug: 272 24649 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 273 24649 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 274 24649 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 275 24649 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 276 24649 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_examine
Debug: 277 24649 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_examine
Debug: 278 24649 arm_adi_v5.c:1204 ahbap_debugport_init():
Debug: 279 24758 arm_adi_v5.c:1265 ahbap_debugport_init(): MEM-AP #0 ID Register 0x14770011, Debug ROM Address 0xe00ff003
Debug: 280 24758 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-assert-pre
Debug: 281 24758 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-assert-pre
Debug: 282 24758 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 283 24758 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 284 24758 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 285 24758 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 286 24758 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_reset assert 1
Debug: 287 24758 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_reset assert 1
Debug: 288 24758 cortex_m3.c:784 cortex_m3_assert_reset(): target->state: halted
Debug: 289 24852 cortex_m3.c:891 cortex_m3_assert_reset(): Using Cortex-M3 SYSRESETREQ
Debug: 290 24883 cortex_m3.c:499 cortex_m3_halt(): target->state: reset
Debug: 291 24883 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-assert-post
Debug: 292 24883 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-assert-post
Debug: 293 24883 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-deassert-pre
Debug: 294 24883 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-deassert-pre
Debug: 295 24883 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 296 24883 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 297 24883 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 298 24883 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 299 24883 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_reset deassert 1
Debug: 300 24883 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_reset deassert 1
Debug: 301 24883 cortex_m3.c:921 cortex_m3_deassert_reset(): target->state: reset
Debug: 302 24883 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-deassert-post
Debug: 303 24883 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-deassert-post
Debug: 304 24883 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 305 24883 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 306 24883 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 307 24883 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 308 24883 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_waitstate halted 1000
Debug: 309 24883 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_waitstate halted 1000
Debug: 310 25008 cortex_m3.c:452 cortex_m3_poll(): Exit from reset with dcb_dhcsr 0x30003
Debug: 311 25039 cortex_m3.c:195 cortex_m3_endreset_event(): DCB_DEMCR = 0x01000501
Debug: 312 25070 target.c:1565 target_write_u32(): address: 0xe0002000, value: 0x00000003
Debug: 313 25117 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 314 25133 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 315 25164 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 316 25180 target.c:1565 target_write_u32(): address: 0xe0002014, value: 0x00000000
Debug: 317 25211 target.c:1565 target_write_u32(): address: 0xe0002018, value: 0x00000000
Debug: 318 25226 target.c:1565 target_write_u32(): address: 0xe000201c, value: 0x00000000
Debug: 319 25242 target.c:1565 target_write_u32(): address: 0xe0002020, value: 0x00000000
Debug: 320 25274 target.c:1565 target_write_u32(): address: 0xe0002024, value: 0x00000000
Debug: 321 25290 target.c:1565 target_write_u32(): address: 0xe0001020, value: 0x00000000
Debug: 322 25321 target.c:1565 target_write_u32(): address: 0xe0001024, value: 0x00000000
Debug: 323 25337 target.c:1565 target_write_u32(): address: 0xe0001028, value: 0x00000000
Debug: 324 25352 target.c:1565 target_write_u32(): address: 0xe0001030, value: 0x00000000
Debug: 325 25383 target.c:1565 target_write_u32(): address: 0xe0001034, value: 0x00000000
Debug: 326 25399 target.c:1565 target_write_u32(): address: 0xe0001038, value: 0x00000000
Debug: 327 25430 target.c:1565 target_write_u32(): address: 0xe0001040, value: 0x00000000
Debug: 328 25446 target.c:1565 target_write_u32(): address: 0xe0001044, value: 0x00000000
Debug: 329 25461 target.c:1565 target_write_u32(): address: 0xe0001048, value: 0x00000000
Debug: 330 25493 target.c:1565 target_write_u32(): address: 0xe0001050, value: 0x00000000
Debug: 331 25508 target.c:1565 target_write_u32(): address: 0xe0001054, value: 0x00000000
Debug: 332 25539 target.c:1565 target_write_u32(): address: 0xe0001058, value: 0x00000000
Debug: 333 25602 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 334 25680 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x9
Debug: 335 25773 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0xfbfbbf6c
Debug: 336 25836 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xfddfebee
Debug: 337 25883 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x9ba5d20
Debug: 338 25945 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x48748d3f
Debug: 339 26007 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0xffffaf9f
Debug: 340 26070 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0xfffffbfe
Debug: 341 26117 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0xed0f5059
Debug: 342 26179 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x12dde3b
Debug: 343 26241 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0xffeff7d1
Debug: 344 26289 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff7ffa
Debug: 345 26352 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0xfb433458
Debug: 346 26414 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x144289e
Debug: 347 26476 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xff1bfef7
Debug: 348 26539 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0xaf00b580
Debug: 349 26586 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xffffffff
Debug: 350 26648 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0xf890f000
Debug: 351 26710 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x0
Debug: 352 26773 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0xaf00b580
Debug: 353 26820 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0x67469c4
Debug: 354 26882 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 355 26944 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 356 27007 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 357 27054 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 358 27054 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0xf890f000, target->state: halted
Debug: 359 27054 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 360 27054 target.c:968 target_call_event_callbacks(): target event 3 (halted)
User : 361 27054 target.c:1234 target_arch_state(): target state: halted
Warn : 362 27054 gdb_server.c:441 gdb_put_packet_inner(): negative reply, retrying
User : 363 27054 armv7m.c:489 armv7m_arch_state(): target halted due to debug-request, current mode: Thread
xPSR: 00000000 pc: 0xf890f000 msp: 0xaf00b580
Debug: 364 27054 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 365 27054 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu curstate
Debug: 366 27054 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu curstate
Debug: 367 27054 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 368 27054 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 369 27054 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 370 27054 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 371 27054 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_waitstate halted 5000
Debug: 372 27054 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_waitstate halted 5000
Debug: 373 27087 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-init
Debug: 374 27087 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-init
Debug: 375 27087 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-end
Debug: 376 27087 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-end
Warn : 377 27118 gdb_server.c:441 gdb_put_packet_inner(): negative reply, retrying
Debug: 378 27165 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,666c6173682065726173655f736563746f7220302030203331’
Debug: 379 27180 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_flash erase_sector 0 0 31
Debug: 380 27180 command.c:133 script_debug(): command - ocd_flash ocd_flash erase_sector 0 0 31
Debug: 382 27197 target.c:1565 target_write_u32(): address: 0x40022004, value: 0x45670123
Debug: 383 27228 target.c:1565 target_write_u32(): address: 0x40022004, value: 0xcdef89ab
Debug: 384 27259 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 385 27275 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08000000
Debug: 386 27292 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 387 27354 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000003
Debug: 388 27354 stm32x.c:75 stm32x_wait_status_busy(): status: 0x3
Debug: 389 27385 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 390 27385 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 391 27416 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08000400
Debug: 392 27432 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 393 27479 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 394 27479 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 395 27510 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08000800
Debug: 396 27526 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 397 27572 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 398 27572 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 399 27588 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08000c00
Debug: 400 27619 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 401 27666 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 402 27666 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 403 27697 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 404 27697 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 405 27728 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08001000
Debug: 406 27744 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 407 27791 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 408 27791 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 410 27822 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 411 27822 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 412 27853 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08001400
Debug: 413 27869 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 414 27916 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 415 27916 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 416 27947 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08001800
Debug: 417 27962 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 418 28009 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 419 28009 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 420 28040 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08001c00
Debug: 421 28056 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 422 28103 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 423 28103 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 424 28134 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08002000
Debug: 425 28150 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 426 28196 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 427 28196 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 428 28228 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 429 28228 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 430 28259 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08002400
Debug: 431 28274 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 432 28322 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 433 28322 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 435 28353 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 436 28353 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 437 28385 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08002800
Debug: 438 28400 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 439 28447 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 440 28447 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 441 28478 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 442 28478 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 443 28509 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08002c00
Debug: 444 28525 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 445 28572 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 446 28572 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 447 28587 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08003000
Debug: 448 28619 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 449 28665 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 450 28665 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 451 28681 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08003400
Debug: 452 28712 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 453 28759 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 454 28759 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 455 28790 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 456 28790 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 457 28821 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08003800
Debug: 458 28837 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 459 28884 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 460 28884 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 462 28915 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 463 28915 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 464 28946 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08003c00
Debug: 465 28962 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 466 29009 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 467 29009 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 468 29040 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 469 29040 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 470 29071 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08004000
Debug: 471 29087 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 472 29133 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 473 29133 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 474 29165 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 475 29165 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 476 29196 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08004400
Debug: 477 29211 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 478 29258 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 479 29258 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 480 29289 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 481 29289 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 482 29322 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08004800
Debug: 483 29337 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 484 29384 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 485 29384 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 487 29415 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 488 29415 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 489 29446 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08004c00
Debug: 490 29462 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 491 29509 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 492 29509 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 493 29540 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 494 29540 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 495 29571 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08005000
Debug: 496 29587 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 497 29634 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 498 29634 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 499 29665 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 500 29665 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 501 29696 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08005400
Debug: 502 29712 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 503 29758 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 504 29758 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 505 29790 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 506 29790 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 507 29821 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08005800
Debug: 508 29836 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 509 29883 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 510 29883 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 511 29914 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 512 29914 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 513 29946 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08005c00
Debug: 514 29961 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 515 30008 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 516 30008 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 518 30039 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 519 30039 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 520 30070 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08006000
Debug: 521 30086 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 522 30133 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 523 30133 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 524 30164 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 525 30164 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 526 30195 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08006400
Debug: 527 30211 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 528 30258 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 529 30258 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 530 30289 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 531 30289 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 532 30320 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08006800
Debug: 533 30336 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 534 30383 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000023
Debug: 535 30383 stm32x.c:75 stm32x_wait_status_busy(): status: 0x23
Debug: 536 30415 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 537 30415 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 538 30446 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08006c00
Debug: 539 30461 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 540 30508 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 541 30508 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 542 30539 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08007000
Debug: 543 30555 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 544 30602 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 545 30602 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 546 30617 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08007400
Debug: 547 30649 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 548 30695 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 549 30695 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 550 30711 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08007800
Debug: 551 30742 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 552 30789 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 553 30789 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000002
Debug: 554 30805 target.c:1565 target_write_u32(): address: 0x40022014, value: 0x08007c00
Debug: 555 30836 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000042
Debug: 556 30883 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 557 30883 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000080
User : 558 30898 command.c:539 command_print(): erased sectors 0 through 31 on flash bank 0 in 3.701206s
Warn : 559 30946 gdb_server.c:649 gdb_get_packet_inner(): acknowledgment received, but no packet pending
Debug: 560 30993 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,666c6173682077726974655f696d616765206d61696e2e62696e2030783038303030303030’
Debug: 561 31008 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_flash write_image main.bin 0x08000000
Debug: 562 31008 command.c:133 script_debug(): command - ocd_flash ocd_flash write_image main.bin 0x08000000
Debug: 564 31025 configuration.c:87 find_file(): found main.bin
Debug: 565 31025 configuration.c:87 find_file(): found main.bin
Debug: 566 31025 target.c:1565 target_write_u32(): address: 0x40022004, value: 0x45670123
Debug: 567 31056 target.c:1565 target_write_u32(): address: 0x40022004, value: 0xcdef89ab
Debug: 568 31087 target.c:1072 target_alloc_working_area(): MMU disabled, using physical address for working memory 0x20000000
Debug: 569 31087 target.c:1134 target_alloc_working_area(): allocated new working area at address 0x20000000
Debug: 570 31087 target.c:1251 target_write_buffer(): writing buffer of 48 byte at 0x20000000
Debug: 571 31165 target.c:1134 target_alloc_working_area(): allocated new working area at address 0x20000030
Debug: 572 31165 target.c:1251 target_write_buffer(): writing buffer of 8482 byte at 0x20000030
Warn : 574 66190 gdb_server.c:441 gdb_put_packet_inner(): negative reply, retrying
Warn : 575 66190 gdb_server.c:441 gdb_put_packet_inner(): negative reply, retrying
Warn : 576 66190 gdb_server.c:441 gdb_put_packet_inner(): negative reply, retrying
Error: 577 66190 ft2232.c:692 ft2232_send_and_recv(): couldn’t read from FT2232
Just tested again after upgrading Eclipse to Galileo and GDB to 7.1
Eclipse Galileo, gdb7.1 (via devkitPro). openOCD 0.4.0
Same error so looks like ocd/ ftdi issue.
I have now moved to the latest versions of openocd and gdb along with libusb-win32 instead of ftdi drivers. I used windows installers from various sites as per my other post on this site. No more errors and can now upgrade easily with windows installers!
