@lefosci - I would view it this way. The OpenScale is open source and SFE encourages you to use and modify the GitHub files as long as you give them attribution. The way I see it - even if SFE would, for whatever reason, turn down your “future” 500 pcs order - I am sure you can either fab yourself or find someone to fab it for you. - Either you are overthinking it or you have some other motivation. — just in case you haven’t looked at their document section for OpenScale; you can see it here: https://github.com/sparkfun/OpenScale - best of luck on your project
