Hi There,
I have a couple of questions on the Papa Soundie and WAV Trigger audio boards that I’m hoping someone can help me with. Apologies if I have missed this information in the specification.
Does the Papa Soundie support multi channel playback?
I know the WAV Trigger has 16 trigger pins but does the WAV Trigger also support Binary Coded Playback over 5 lines like the Papa Soundie?
I’m looking for something that supports both of the these features.
Chris
Hi Chris, thanks for posting your question!
The Papa Soundie does not support playing more than one sound at a time but the WAV Trigger does and the WAV Trigger doesn’t support binary triggering like the Papa Soundie.
One thing you could do is program an Arduino to decode a binary input and then have the Arduino send a signal to the WAV Trigger to play a specified track. You’d need to write a little bit of code to do that, but it would be the only way you can get the best of both worlds.
Many thanks for your answer.
Chris
