Its well known that application Software is copied in various countries on an enormous scale.
However, PCB Layout software is very rarely copied.
For example, undercover “industrial spys” went to China and were not able to buy bootlegged copies of Altium, Cadstar, Pads, Pulsonix, Mentor Graphics.
-they were able to buy plenty of other bootlegged software.
Is the reason that the above softwares are not bootlegged in China (for example) because there are no “idiot’s guides” to the above softwares?
In other words, if one uses any of the above softwares, then one is highly likely to encounter serious difficulties in using the software, and due to the fact that the User Manuals are kept , shall we say, “not that crystal clear”, then if you get stuck using one of these PCB Layout packages, then quite often, the only way to get round your problem is to seek help directly from the PCB Layout software company itself…when you do request help from them, they can then check that you have payed your license fee.
…In this way, the aforementioned PCB Layout softwares manage to avoid having their PCB Layout software getting bootlegged.
Is this true?
Its just that I notice that in the case of the above mentioned softwares, there are no manuals or tutorials etc which aren’t originated by the designers of the software itself.
In the case of the Eagle PCB layout software, which IS widely used in China, there are loads of “idiots guides” for it, authored by “every man and his dog”…not only that, but the limited version of eagle is free, so nobody has to copy it, as its free anyway.
So is this the reason why there are no crystal clear “idiot’s guides” to PCB Layout Software’s mentioned above?..ie because they are worried about getting the software bootlegged?
And why are there no learning materials for the aforementioned pcb layout softare packages that are authored externally to the actual software designer company?
That is, why are there no externally authored learning materials for eg Altium, Cadstar, Pads, Mentor graphics, pulsonix, Orcad, etc etc?
