Anyway to know which leg of the 3 sided end of the photo interrupter goes where?
I can’t get mine to work, and I’m wondering if I mixed up the legs on the 3 sided end. I’ve also cut them short now and hope to be able to remove and replace the sensor, but how can I tell which leg goes where now?
Thank you!
It need to be mounted on the printed-side of the PCB
https://cdn.sparkfun.com//assets/parts/ … 322-02.jpg
So that it ends up looking like this
https://cdn.sparkfun.com//assets/parts/ … 9322-4.jpg…it only works correctly in this position
Is the resistor in-place as well?
This was the issue. I had it soldered on wrong side of the board. Thanks for the help.
