Power Target mode isn't working. Did i kill my Pocket AVR?
I was just using my Pocket AVR connected to a Discipad and ran the command:
avrdude -c usbtiny -p atmega328p
after that I heard the Windows 10 disconnect sound and all LEDs on the Pocket AVR were off.
Unplugging all Cables and plugging it back in did nothing. The No Power mode still works fine.
In Power Target mode the Fuse gets up to 76Cº. In Power Target mode i measured around 4 Volt in No Power mode around 0.04 Volt on the Fuse.
What could be the problem and what Troubleshooting steps should i try?
Thanks in advance.
If you disconnect the programmer from your target board, does it appear to work and not get hot then?
