I am planning on purchasing a standard gear motor (https://www.sparkfun.com/products/12219) and am wondering what I need to buy to power it. I just need it spinning at a constant rpm so it shouldn’t require any programming just a constant 12 volts. Is there a 12 volt dc adapter on sparkfun that I can use to power it or should I be looking elsewhere?
If the motor is brushed then just use a 12v power supply and if you could it would be better if you could adjust the speed.
Look on Hobbyking. Com if spark fun don’t have a power supply you need
Thanks for your post!
[One of these will work as a power supply. If you need an easy way to attach wires to the plug on that power supply, our [female barrel jack adapter will do that for you too.](https://www.sparkfun.com/products/10288)](https://www.sparkfun.com/products/9442)
