Is it possible to power MicroMod Machine Learning Carrier Board with Battery Babysitter - LiPo Battery Manager. If it is possible, then can you please share the hookup guide for the same? I really appreciate any help you can provide.
Nilanjan
Nilanjan
Sure - While we don’t have a tailor-made guide for doing so, but you can combine these 3 documents to learn how to:
https://cdn.sparkfun.com/assets/learn_t … ptions.pdf
Use these pin descriptions to wire the power input to the MicroMod
https://learn.sparkfun.com/tutorials/ba … 1615791300
Wire your Battery Babysitter according to its hookup guide, and use its Vout to connect to the MicroMod
https://learn.sparkfun.com/tutorials/mi … 1615791300
And follow the MicroMod hookup guide to run some example sketches and ensure everything is functional
Hope this helps!
Awesome…Thanks for the help…
