XPav
May 23, 2022, 8:57pm
1
I have an RTK Facet. I have configured it for PPS output on its data connection, and am looking at the Green Wire output on the Data Point.
I get something that seems to be not a PPS. It comes out once a second, but is… something else.
Any thoughts on how to make it a proper PPS? Configure the F9P?
Hi @xPav ,
That looks like serial data (NMEA and/or UBX). It will be output once per second too.
It looks like you have the correct option selected: “PPS Out/Event Trigger In”
Please try changing the setting again - and exit the menu. Do you still see the same thing on your oscilloscope?
You can find the new on-line product manual here:
https://sparkfun.github.io/SparkFun_RTK … -data-port
Our RTK expert is out of the office today. He should be able to reply tomorrow.
XPav
May 24, 2022, 3:54pm
3
HI Paul,
If I change it to NMEA and back to PPS I get nothing on that line, it just stays high.
Switching to I2C and the ADC config changes the signal to what I presume is the right thing (but I didn’t look closely).
XPav
May 24, 2022, 4:05pm
4
So it does work, mostly. after setting the port to NMEA and back to external trigger, I still had to go enable and configure the external trigger in the other port menu.
It however, requires one to go through the NMEA/external setting whenever the system is power cycled.
This sounds like a firmware issue. I hope to have a look later today.
I’ve moved this issue to the repo so we can track it: https://github.com/sparkfun/SparkFun_RT … issues/142
Hi @XPav - do you mind moving the conversation over to github (https://github.com/sparkfun/SparkFun_RT … issues/142 )? If you are more comfortable here, that’s fine, let me know.
I cannot replicate your issue. As soon as I select PPS I start to see PPS signals on the green wire connected to the DATA port (black wire connected to logic analyzer ground):
https://user-images.githubusercontent.c … 783394.png
https://user-images.githubusercontent.c … 24d34d.png
Also, after a power cycle, the PPS continues as expected.
Please let me know what I can try differently.
