Pressure Sensor with Arduino
I am trying to get started with arduino so it would be great if you guys could point me in the right direction. I am basically looking to use a pressure sensor (which acts as a variable resistor) to moderate the amount of voltage a power supply puts out. For example, a pressure is applied to the sensor and then based on that pressure a proportional amount of voltage is applied to a piezoelectric transducer. What board should I buy? How should I go about doing this? I know the fundamentals of programming and I have a small bit of experience with arduino by the way. Thanks
What kind of control signal does your PS require ? What range of force/pressure are you expecting to use ? What’s going to be applying that pressure ?
I am using this sensor to sense air pressure (wind at high velocity).
https://www.sparkfun.com/products/11207
If all you need is 1 analog input and one ??? output, then any “Arduino” board should suffice. Perhaps even an Adafruit Trinket. One thing I’d think about doing is linearizing the sensor response via a lookup table and interpolation. That might rule out the Trinket.
