Hey all,
Im using a Blue Smirf Silver with a Mega board. I seem to have a problem with the GET Commands. I set the COM Port to 115200 baud for the Mega. After i upload the example sketch i then open the serial monitor and type in the “$$$”. My problem is that after i do that, the serial monitor does not return the line “CMD” or anything else for that matter. Any help would be really appreciated! Thanks!!!
I changed the COM port from 115200 to 9600 and back again. No dice. I have also changed the baud rate on the serial monitor from 9600 to 115200 as well. Again, no dice. I know that something is happening because the onboard LED begins flashing quickly after typing the $$$ into the serial monitor, but the “CMD” never shows up. Any other suggestions/resources i might have missed?
How is everything connected? A pic would suffice.
