I am new to ARM and just trying now to program an Olimex SAM7-MT256 board with WinARM tools (including openOCD) and the ARM-USB-OCD programmer.
In the programming phase, I get some communication going on, then the green LED on the ARM-USB-OCD becomes amber and nothing more seems to happen.
Config file:
Log file from OpenOCD:#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc “Olimex OpenOCD JTAG A”
ft2232_layout “olimex-jtag”
ft2232_vid_pid 0x15BA 0x0003
jtag_speed 0
jtag_nsrst_delay 200
jtag_ntrst_delay 200
#use combined on interfaces or targets that can’t set TRST/SRST separately
reset_config srst_only srst_pulls_trst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target
#target arm7tdmi
target arm7tdmi little run_and_halt 0 arm7tdmi
run_and_halt_time 0 30
For more information about the configuration files, take a look at:
http://openfacts.berlios.de/index-en.ph … p+Debugger
Programming with OPENOCD
C:\Program Files\openocd-2006re93\bin\openocd-ftd2xx.exe -d3 -f at91r40008_armusbocd.cfg
Info: openocd.c:82 main(): Open On-Chip Debugger (2006-08-31 15:00 CEST)
Debug: jtag.c:1209 jtag_init():
Debug: ft2232.c:941 ft2232_init(): ‘ft2232’ interface using FTD2XX with ‘olimex-jtag’ layout
Debug: ft2232.c:1010 ft2232_init(): current latency timer: 2
Debug: ft2232.c:1253 olimex_jtag_init(): 80 08 1b
Debug: ft2232.c:1296 olimex_jtag_init(): 82 09 0f
Debug: ft2232.c:224 ft2232_speed(): 86 02 00
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 1
Debug: jtag.c:1095 jtag_reset_callback():
Debug: openocd.c:98 main(): jtag init complete
Debug: arm7_9_common.c:655 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 0
Warning: arm7_9_common.c:679 arm7_9_assert_reset(): srst resets test logic, too
Debug: ft2232.c:718 olimex_jtag_reset(): trst: 0, srst: 1, high_output: 0x03, high_direction: 0x0f
Debug: arm7_9_common.c:718 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 2
Debug: ft2232.c:718 olimex_jtag_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: openocd.c:102 main(): target init complete
Debug: openocd.c:106 main(): flash init complete
Debug: gdb_server.c:1115 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: embeddedice.c:156 embeddedice_read_reg_w_check(): 1
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 3
Debug: arm7_9_common.c:781 arm7_9_halt(): target->state: running
Debug: embeddedice.c:252 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:252 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:252 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:252 embeddedice_write_reg(): 13: 0x000000f7
Debug: arm7_9_common.c:619 arm7_9_poll(): DBGACK set, dbg_state->value: 0x19
Debug: embeddedice.c:252 embeddedice_write_reg(): 0: 0x00000005
Debug: embeddedice.c:252 embeddedice_write_reg(): 12: 0x00000000
Debug: arm7_9_common.c:911 arm7_9_debug_entry(): target entered debug from Thumb state
Debug: arm7_9_common.c:915 arm7_9_debug_entry(): r0_thumb: 0x0001a677, pc_thumb: 0x000001e4
Debug: arm7_9_common.c:938 arm7_9_debug_entry(): target entered debug state in Supervisor mode
Debug: arm7_9_common.c:949 arm7_9_debug_entry(): thumb state, applying fixups
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r0: 0x0001a677
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r1: 0x00400000
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r2: 0x000e0000
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r3: 0x00200048
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r4: 0x00000063
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r5: 0x0000000c
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r6: 0x00000000
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r7: 0x00000800
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r8: 0x00000040
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r9: 0x00010000
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r10: 0x00000000
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r11: 0x82008000
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r12: 0x00001000
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r13: 0x0020ffa4
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r14: 0x0000034d
Debug: arm7_9_common.c:974 arm7_9_debug_entry(): r15: 0x000001de
Debug: arm7_9_common.c:980 arm7_9_debug_entry(): entered debug state at PC 0x1de
Debug: target.c:442 target_call_event_callbacks(): target event 0
Any hint to help me get started will be appreciated.
