I wonted to submit a design of PCB. I’m using eagle and I did everithing as tutorial about CAM said. But I didn’t got the .sol file out of processor. Can enibodey please tell me, what to do?
Open up the gerb274x.cam file and then open up your board file. Select the “Solder Side” tab. Make sure that the “File” text box has ‘.sol’ (without the single quotes) in it. Make sure that ‘bottom’, ‘pad’, and ‘vias’ layers are selected. Click on “Process Section” and you should get your solder side layer created.
Hope this helps,
gm
Thank you for your answer. I’ve solved my problem. The .sol file was allready there, but I just haven’t seen it because it my computer hasn’t shown my extensions xD.
