Product Recommendation
Hello, and thanks. New to the electronics hobby. Want to use Wifi for controls. For my intended purposes, seems cheaper than R/C, since already have a laptop. Plus, will learn more.
So, to get right to it. Since I’m a beginner, thought I should definitely ask…what Wifi board/module would you recommend? Project description and parameters below.
Project info:
The project I’m looking to build is a two-wheeled robot. Two micro drive motors for locomotion (with optional 6V or 12V), with just a small ball caster wheel to keep from dragging. Will have a third drive motor attached to front as sort of drill (battle robot sort of thing). It’s small, too, so size is a consideration.
Many thanks in advance for any help you can give me,
jaysmithcreate
Greetings, thanks for the post.
We have a few tutorials that will give you a good idea on what your projects entails below:
https://www.sparkfun.com/news/2642?_ga= … BEQAvD_BwE
https://learn.sparkfun.com/tutorials/wi … BEQAvD_BwE
Let us know if you have any specific questions regarding specific products in their respective forums.
Cheers and I hope you have a good weekend.
