Program not running the same as when in debug.
Using my AVR dragon I run my program in debug mode and it runs fine. However when i actually flash the device and let it run on its own it doesn’t do what it should at all. What would be the cause of this?
Could you let us know what it does and does not do in the two environments? Then maybe we can tell you why. Attached code would also be helpful.
Dead AVRdragon was the problem. The debugWire stuff worked but not the ISP. I guess I believe everyone who told me its very fragile now.
