programming lpc17xx with openocd
Does someone succeeds to program lpc17xx microcontrollers quite out of the box
using openocd ?
If the answer is yes, what programmer do you use ?
Cédric
OpenOCD can support lpc17xx.
You can use any JTAG dongles supported by OpenOCD.
I tested it OK on my Versaloon(vsllink).
Ok thanks for the info,
Anyway meanwhile I’ve bought a jtagkey-tiny programmer from amontec and a lpc1766 .
I’ll try that very soon .
SimonQian:
Do you have the GDB init commands that you used for this?
