programming olimex board(at91sam7s64) with SAM BA
hi,
i program the this board with SAM BA but it’s really take time each time to recovery proccess( connect TST PIN & unconnect & …)
is there any way to program chip easier or only one recovery is needed?
i want to save SAM BA boot code in flash & left & the user code program after it.
thanks
I suppose, you can send your program into the ram via samba , without using the flash. The code should compiled with the RAM-Memory mapping.
I don’t thing ram-programming is to complex - I extendet the proto-board with a simple press-button - its easyer - but then you have still to wait 5-10 seconds for the recovery precedure…
