If you can, get one of the sockets and beep it out, just route both pins 10 and 11 back to your micro either directly (if you have a spare I/O pin) or thru two 0-ohm resistors (only load one).
We apologize. I was not getting auto responding emails from the forum so was unaware of a response.
For future (for everyone!), emailing us directly at techsupport@sparkfun.com is the best way to contact us regarding these issues. Emails take first priority for us as our volume has increased proportionately with our sales.
Moving on…
On our breakout board (BOB-00204), COM and CD short when a card is inserted. When no card is present, there is not a short between them. The same thing happens with WP and COM if a card is inserted with the write protect switch engaged.
Does that answer your questions? Sorry for the delay, I just didn’t see the post until now.
I just took a look at this. In the SFE library that I have, these labels and pin definitions are the same.
I think you are confused by the schematic symbol and thinking it has some relation to the actual physical layout. The schematic symbol can have those pins in any order or anyplace. It means nothing to the physical layout, those pins are attached to the physical footprint in the library package definition.
