In case you want to communicate via serial connection to a telit GM862 module, this class might be useful for you. Modern GM862 modules have a python interpreter included. This Pyhon class is meant for a PC running Python and communicating with the module. If you want to send/ receive SMS or check GPS location, this might be for you. Though GPRS has not been looked into very much.
# Python Serial Class for GM862
# To communicate with a GM862 mobile device via AT commands
# http://www.gm862.com/
# modern gm862 modules have a python interpreter on board
# http://iad.zhdk.ch
# http://iad.projects.zhdk.ch/physicalcomputing/
# Interaction Design, Zurich University of the Arts ZHdK
# Free to use non commercially - Provided as is, use at own risk
# You need the pySerial Library by Chris Liechti
# http://pyserial.wiki.sourceforge.net/pySerial
# Used with a Sparkfun GM862 Evaluation Board USB EVK V3
# http://www.sparkfun.com/commerce/product_info.php?products_id=281
# settings: SELINT = 2; we communicate over the selint 2 interface
# SMSMODE = 1; improved SMS commands operation is on
import serial
import time as zeit
# Start GM862 Class Definition --------------------------------------
class GM862(object):
def __init__(self, interface):
self.interface = interface
self.ser = None
self.openSerial()
self.started = False
# Serial Methods -------------------------------------------------------------
def openSerial(self):
self.ser = serial.Serial(self.interface, 9600, 8,'N',1, rtscts=1, timeout=2)
self.ser.open()
print "GM862 "+ str(self.interface) +" open -------------------------\n"
def closeSerial(self):
self.ser.close()
print "GM862 "+ str(self.interface) +" close ------------------------\n"
def start(self, pin):
pin -> 4 digit int to activate SIM, string
print ":: begin startup routine :: ------------------------------------" + "\n"
# enter pin -----------------------------------------------------------
print "entering pin:"
# always terminate commands with carriage return ascii 13
self.ser.timeout = 5
self.ser.write('AT+CPIN=' + pin + chr(13))
self.ser.readline(size=None, eol=chr(13))
print "PIN response: " + self.ser.readline(size=None, eol=chr(13)) + "\n"
self.ser.flushInput()
zeit.sleep(0.03)
# network registration -------------------------------------------------
print 'enable network registration result code:'
self.ser.timeout = 2
self.ser.write('AT+CREG=1' + chr(13))
print "CREG response: " + self.ser.readline(size=None, eol=chr(13)) + "\n"
zeit.sleep(0.03)
self.ser.timeout = 30
print 'request network registration report:'
self.ser.write('AT+CREG?' + chr(13))
resultCode = self.ser.readline(size=None, eol=chr(13))
print resultCode
if resultCode[-2] == "0":
print "not registered, searching for operator" + "\n"
elif resultCode[-2] == "1":
print "registered to home network" + "\n"
elif resultCode[-2] == "2":
elif resultCode[-2] == "3":
print "registration denied" + "\n"
elif resultCode[-2] == "4":
print "unknown" + "\n"
elif resultCode[-2] == "5":
print "registered, roaming"
zeit.sleep(0.03)
# automatic band selection ----------------------------------------------
print 'set automatic band selection:'
self.ser.timeout = 10
self.ser.write('AT#AUTOBND=2' + chr(13))
str(self.ser.readline(size=None, eol=chr(13)))
print "AUTOBND response:" + self.ser.readline(size=None, eol=chr(13)) + "\n"
zeit.sleep(0.03)
# enable error reporting ------------------------------------------------
print 'enable error reporting:'
self.ser.write('AT+CMEE=2' + chr(13))
print "CMEE response: "+self.ser.readline(size=None, eol=chr(13)) + "\n"
zeit.sleep(0.03)
# ready for input? ------------------------------------------------------
print 'test at command'
self.ser.write('AT' + chr(13))
print "AT response: " + self.ser.readline(size=None, eol=chr(13)) + "\n"
zeit.sleep(0.03)
self.started = True
print ":: end startup routine :: ------------------------------------" + "\n"
def sendSMS(self, number, message):
number -> string, cell number in intl. format +41791234567
message -> string, message text
-> returns message Id as string
print 'sending sms to ' + str(number) + '---------- --- -- -\n'
# send SMS ----------------------------------------------------------------
print 'send SMS to ' + str(number)
self.ser.write('AT+CMGS=' + number +',145'+ chr(13))
cmgsResponse = self.ser.readline(size=None, eol=chr(13))
print cmgsResponse
if cmgsResponse == "\n> ":
print "Ready to send message:"
self.ser.timeout = 60
self.ser.write(message)
self.ser.write(chr(0x1A))
# read message reference or error
messageId = self.ser.readline(size=None, eol=chr(13))
ok = self.ser.readline(size=None, eol=chr(13))
zeit.sleep(0.03)
if ok == '\nOK\r':
print "SMS sent " + ok.lstrip('\n') + " SMS Id: " + messageId.lstrip('\n+CMGS: ')
return messageId.lstrip('\n+CMGS: ') # return only id number as string
else:
print "ERROR: " + ok
return ok
else:
print "ERROR no > prompt: " + cmgsResponse
def saveSMStoSIM(self, number, message):
message -> string to be stored
returns message id
print "save sms to sim --------------------------------------"
# write SMS to SIM
self.ser.write('AT+CMGW=' + number + '145' + chr(13))
self.ser.readline(size=None, eol=chr(32)) # waiting for chr(32) >
self.ser.write(message + chr(0x1A))
zeit.sleep(0.03)
if ok == '\nOK\r':
print "SMS saved " + ok.lstrip('\n') + "SMS Id: " + messageId.lstrip('\n+CMGW: ')
return messageId.lstrip('\n+CMGW: ') # return only id number as string
else:
return ok
def getSMSspace(self):
returns list[used sms, max sms]
print "request sms space on sim -------------------------------------------"
# request free space ------------------------------------------------------
print 'request free sms space'
self.ser.write('AT+CPMS?' + chr(13))
simResponse = self.ser.readline(size=None, eol=chr(13))
zeit.sleep(0.03)
if ok == '\nOK\r':
simResponseList = simResponse.split(',')
print "SMS on SIM: " + simResponseList[1] + " used out of " + simResponseList[2] + "\n"
return [simResponseList[1], simResponseList[2]]
else:
print "ERROR \n"
return "ERROR"
def getSMSindex(self):
-> returns list with used SMS indices on SIM
[0,1,2,3,7,10]
print "Get SMS indices on SIM card --------------------------------------"
# get SMS indices -----------------------------------------------------
print "requesting indices"
self.ser.write('AT+CMGD=?' + chr(13))
#print self.ser.readlines(sizehint=None, eol=chr(13))
indexResponse = self.ser.readline(size=None, eol=chr(13))
if ok == '\nOK\r':
print indexResponse
indexResponse = indexResponse.replace('\n+CMGD: (', '')
indexResponse = indexResponse.replace('),(0-4)\r','')
indexResponse = indexResponse.split(',')
zeit.sleep(0.03)
print str(indexResponse) + "\n"
return indexResponse
else:
print "ERROR \n"
return "ERROR"
def deleteSMSonSIM(self, id):
id -> SMS index on SIM card, string
print "Delete SMS on SIM card --------------------------------------"
# delete sms at index -----------------------------------------------------
print 'delete SMS at index: ' + id
self.ser.write('AT+CMGD=' + id + chr(13))
zeit.sleep(0.03)
if ok == '\nOK\r':
print ok.lstrip('\n') + '\n'
return "OK"
else:
return "ERROR"
def deleteAllSMS(self):
simply delete all stored SMS
print "Delete all SMS from SIM card -------------------------------------"
# delete all SMS x --------------------------------------------------------
print 'delete all SMS on SIM '
self.ser.timeout = 25
self.ser.write('AT+CMGD=1,4' + chr(13))
zeit.sleep(0.03)
if ok == '\nOK\r':
return "OK"
else:
return "ERROR"
def SMSsetup(self):
general SMS settings
-> returns "OK" or "ERROR"
# SMS command operation mode ----------------------------------------------
print 'set sms command operation mode'
self.ser.write('AT#SMSMODE=1' + chr(13))
ok1 = self.ser.readline(size=None, eol=chr(13))
zeit.sleep(0.03)
if ok1 == '\nOK\r':
print ok1.lstrip('\n') + '\n'
else:
print "ERROR: " + ok1
return "ERROR"
# SMS Text mode ----------------------------------------------------------
print 'set TEXT mode not PDU: '
self.ser.write('AT+CMGF=1' + chr(13))
ok2 = self.ser.readline(size=None, eol=chr(13))
zeit.sleep(0.03)
if ok2 == '\nOK\r':
print ok2.lstrip('\n') + '\n'
return "OK"
else:
print "ERROR: " + ok2
return "ERROR"
def listSMS(self, flag):
flag -> what to read, string
"REC UNREAD" - new message
"REC READ" - read message
"STO UNSENT" - stored message not yet sent
"STO SENT" - stored message already sent
"ALL" - all messages
-> returns list of requested messages
['header','message']
['index, flag, sender, phonebook, time','Message Text Here']
['3,"REC READ","+41791234567","","09/08/05,16:30:03+08"\r', '\nMessage Text Here\r']
# read messages ------------------------------------------------------
print 'listing messages with flag: ' + flag
self.ser.write('AT+CMGL='+ flag + chr(13))
# read until an 'OK' arrives
ok = 0
readlist = []
while ok == 0:
line = self.ser.readline(size=None, eol=chr(13))
#print line
# stop reading when OK arrives
if line.startswith('\nOK\r'):
ok = 1
# add only interesting messages into a list
if line.startswith('AT+CMGL') == False and \
line.startswith('\nOK\r') == False and \
line.startswith('\r') == False and \
line.startswith('\n\r') == False:
# take out '\n+CMGL: ' at beginning of message
line = line.replace('\n+CMGL: ', '')
line = line.replace('\r', '')
line = line.replace('\n', '')
readlist.append(line)
zeit.sleep(0.03)
#print readlist
return readlist
# GPRS functions have not been fully tested, more later ----------------------------
def GPRSsetup(self, apn, conId, cid, pktSz, maxTo, connTo, txTo):
apn: depending on your provider, string
APN = Access Point Name
switzerland: sunrise = "internet"
orange = "internet"
swisscom = "gprs.swisscom.com"
conId: socket connection identifier 1-6, string
cid: pdp context identifier 1-5, string
pktSz: packet size 0, automatic; 1-1500 bytes, string
maxTo: inactivity timeout 0, no timeout; 1-65535 seconds, string
connTo: connection timeout 10-1200 milliseconds, string
txTo: data is sent if less bytes than packet size 0, no timeout 1-255 hundred milliseconds
-> returns OK or ERROR
# define PDP packet data protocol context -----------------------------------------
print 'setting pdp context '
self.ser.write('AT+CGDCONT=1,IP,internet' + chr(13))
zeit.sleep(0.03)
if ok1 == '\nOK\r':
else:
return "ERROR"
# socket configuration ------------------------------------------------------------
print 'socket configuration'
self.ser.write('AT#SCFG='+ conId + ',' + cid + ',' + pktSz +',' + maxTo +',' + connTo + ',' + txTo + chr(13))
zeit.sleep(0.03)
if ok2 == '\nOK\r':
return "OK"
else:
return "ERROR"
def GPRSstatus(self, cid, stat):
de/ activate gprs context
cid -> context identifier
0; GSM context
1-5; pdp context
stat -> 0; deactivate
1; activate
returns -> IP after activation
ERROR when already activated
OK when deactivated
# gprs status ------------------------------------------------------------
print 'de/ activate context'
self.ser.timeout = 150
self.ser.write('AT#SGACT='+ cid + ','+ stat + chr(13))
zeit.sleep(0.03)
if ok == '\nOK\r':
print ok.lstrip('\n') + 'context deactivated' +'\n'
return "OK"
elif ok.startswith('\n+CME ERROR'):
print ok
return "ERROR"
elif ok.startswith('\n#SGACT'):
print 'IP ' + ok.lstrip('\n#SGACT: ')
return ok.lstrip('\n#SGACT: ')
def GPRSdial(self, connId, txProt, rPort, IPaddr, closureType, IPort, connMode):
open socket connection
connId -> socket 1-6
txProt -> 0: TCP, 1: UDP
rPort -> remote host port 0 - 65535
IPaddr -> IP address xxx.xxx.xxx.xxx or host name www.google.com
closureType -> 0: local host closes when remote has closed
255: local host closes after escape sequence (+++)
IPort -> UDP connection local port 0-65535
connMode -> 0 online, 1 command mode
-> returns CONNECT, OK, or ERROR according to connMode
# socket dial ------------------------------------------------------------
print 'opening socket connection to ' + IPaddr
self.ser.timeout = 140
self.ser.write('AT#SD='+ connId + ','+ txProt +','+ rPort +','+ IPaddr +','+ closureType +','+ IPort +','+ connMode+ chr(13))
zeit.sleep(0.03)
print ok
return ok
def GPRSsuspend(self):
suspend open socket connection
if closureType was set 255 in AT#SD
# suspend socket ---------------------------------------------------------
print 'suspend open socket '
self.ser.write('+++'+ chr(13))
print "1 "+ self.ser.readline(size=None, eol=chr(13))
print "2 "+ self.ser.readline(size=None, eol=chr(13))
print "3 "+ self.ser.readline(size=None, eol=chr(13))
zeit.sleep(0.03)
def GPRSrestore(self, connId):
restore suspended connection
connId -> 1-6, string
# restore socket connection ----------------------------------------------
print 'restore socket connection'
self.ser.write('AT#SO'+ connId + chr(13))
zeit.sleep(0.03)
# resume suspended connection
AT#SO=1
# close connection without deactivating gprs context
AT#SH=1
# socket listen
AT#SL
# queryDNS
AT#QDNS="google.com"
# GPS --------------------------------------------------------------------------
def GPSreset(self, type):
reset GPS controller
flag 0 - 3, string
0; Hardware reset
1; Coldstart (No Almanach, No Ephemeris)
2; Warmstart (No Ephemeris)
3; Hotstart (With stored Almanach and Ephemeris)
-> returns OK
# reset GPS ----------------------------------------------------------------
print 'resetting GPS controller'
self.ser.write('AT$GPSR=' + type + chr(13))
zeit.sleep(0.03)
if ok == '\nOK\r':
return "OK"
else:
print ok
return "ERROR"
def GPSgetPos(self):
get acquired position
-> returns list
[UTC time, latitude, longitude, horizontal dilution, fix, speed Kmh, speed knots, date, satellites]
self.ser.write('AT$GPSACP' + chr(13))
data = self.ser.readline(size=None, eol=chr(13)) # data
zeit.sleep(0.03)
data = data.strip('\n$GPSACP: ')
data = data.strip('\r')
data = data.split(',')
print data
return data
# Example Code -------------------------------------------------------
GM = GM862('/dev/tty.usbserial-A1000RiF')
#GM.openSerial()
# startup procedure with SIM Pin - set general settings
#GM.start('1234')
# SMS setup ------------------------------
#GM.SMSsetup()
# send SMS to number xy
#GM.sendSMS('+41791234567','testmessage')
# check how many SMS are saved on SIM
#GM.getSMSspace()
# save an SMS to SIM card
#GM.saveSMStoSIM('+41791234567', 'noch eine testmessage')
# delete SMS on SIM
#GM.deleteSMSonSIM('1')
# delete all SMS on SIM
#GM.deleteAllSMS()
# indices of saved SMS on SIM
#GM.getSMSindex()
# SMS settings to be noticed of incoming messages
#print GM.listSMS('ALL')
# GPRS ist not fully tested ... so please be careful and look closely ------------------
# GPRS settings ---------------------------
#GM.GPRSsetup('internet','1','1','100','0','500','1')
# GPRS status on/ off
# on
#GM.GPRSstatus('1','1')
# off
#GM.GPRSstatus('1','0')
# dial socket
#GM.GPRSdial('1', '0', '80', 'www.google.com', '255', '0', '1')
# suspend socket connection
#GM.GPRSsuspend()
# restore suspended socket connection
#GM.GPRSrestore('1')
# GPS controller reset
#GM.GPSreset('1')
# GPS get position
#GM.GPSgetPos()
GM.closeSerial()
