Dear all,
As I know, the edge board uses baud rate as 921600 bps during flashing, and then change the baud rate to its operational baud rate which is 115200 after booted-up when I use “make bootload”.
Q) Can I change its operational baud rate from 115200 to higher rate such as 460800 or 921600 bps by changing the BSP and the source codes?
If then, please let me know which BSP or source codes should be changed.
Thank you.
