Question about the microSD shield (should be an easy question)
Can I use the same library as the QWIIC microSD breakout so I can use the same code as before if I replace the qwiic microsd with the shield? I just want to reduce the footprint.
If your current device is https://www.sparkfun.com/products/13743 and want to replace it with https://www.sparkfun.com/products/12761, you can use the same library. But you may have to adjust the CS-pin depending on how you connected now. The other point is that on the 13743 a card-detect switch option is available, which is not available on the 12761.
I am actually using this currently,
https://www.sparkfun.com/products/15164
