I have this product … www.sparkfun.com/products/15010
I need to make the robot fulfill this …
display 2 degrees of freedom
demonstrate that you are using a sensor input.
Can anyone help? Does it have the correct sensors to do this?
Thank you!
Thank you!
The kit comes with 2 independently controlled motors (2 degrees of freedom) and the controller board has a built in compass and accelerometer which would count for your sensors. You have the physical aspects of the project covered but it will be up to you to program it to make a working robot out of it that can demonstrate that you integrated everything properly.
-Bill
I think that’s the problem. We have the kit built and have it coded to move, go right, it can spin. But how do you incorporate coding to incorporate the sensors?
