Does the kit incude all the component to set up it?
And is it possible to know how to mount the encoder on the motor?
Are there any instructions?
I’m new in the forum, so sorry if I’m outside the topic.
Piero
Piero
Hi Piero.
The kit includes all the electrical parts but may not have all the mechanical parts depending on how you choose to mount the sensors. There is a data sheet (link below) that has a photo in it showing one possible way to mount the sensor with a zip tie (zip tie not included) but you could use tape or glue to mount the sensor as well.
The magnet needs mounted to either the motor shaft or wheel shaft and the sensor needs mounted beside the magnet so that it can sense the magnet rotating.
