Wheel Encoder Kit with Multi-Chassis - 4WD Kit ??
Can the
Wheel Encoder Kit
https://www.sparkfun.com/products/12629
be used with the
https://www.sparkfun.com/products/12089
The motor gearboxes are different than the redbot’s, so I want to be sure.
-Chris
so… I realized after posting that the encoder get’s mounted on the back of the motor. So I guess it’s more a question of fitting in the multi-chassis casing?
It doesn’t look like the motors used in the multi-chassis have a shaft on the rear, so the encoder wheel can’t be mounted there, You can still use the hall sensors from the encoder kit and epoxy some magnets into the wheels themselves to trigger them.
/mike
