I am trying to get the 3D location of the tops of some posts. I am getting great data within 15mm which is what I was hoping for. My biggest question is how do I receive the altitudes of the sparkFun RTK Facet on top of the posts. The goal is to be able to tell someone to drill holes x distance down from each hole. The Marks_data.csv file is only accurate to the nearest 0.1m and I was wondering if there was a better way to retrieve the altitude values.
You can Bluetooth a smartphone or tablet to the Facet and use as a data collector.
There are Freeware apps such as SW Maps that will store the 3D points for you, and even export to a spreadsheet.
Bluetooth and SW maps was not working well with my iPhone for some reason so I gave up on that. I am hoping to just mark the data on SD card for ease of use for anyone on my team.
I did that, my phone and the RTK Facet kept disconnecting from each other. It likely is my phone’s fault but was really just wondering if there was a way to log more accurate altitudes on the microSD cards.
