I only took a picture of the part I am having trouble with, the other had been already mounted on my robot, iy would br too much trouble to disassembly the robot now as i am in debug.
Note pin 3 and 2 for address 9(solder on both that i did not do) I buzzed these pins and 3 is shorted and 2 is not. i then used address 0x5d ( which works on my first unit) and then address 0x61 ( just in case) -neither worked.
Not sure how that happened, but I’ll get a replacement sent out ASAP!
Replacement ticket # 22789 has been issued. A customer service representative will process the ticket and send a replacement out free of charge using a similar shipping method you used for your original order. You should also receive an E-mail notification that the replacement is on the way. Please do not send your device(s) back.
