I’m inquiring in regard to the distance range of the Qwiic RFID Reader (SEN-15191). Any info would be greatly appreciated.
A few inches but it depends on the card you use.
In the hook up guide it says " Heads up! For the scope of the tutorial, we will be using the ID-12LA RFID reader. The board is also compatible with the following ID-xxLA modules at 125kHz . The range varies with each model. Keep in mind that you will need to an external antenna for the ID-3LA."
https://learn.sparkfun.com/tutorials/sparkfun-qwiic-rfid-idxxla-hookup-guide
This doesn’t answer OP’s question.
