Have a new BME280 from SparkFun, have the proper library installed and the red LED comes on.
Every sketch I have tried shows no communication with the BME280.
Asking for technical help, have to start somewhere.
Thank-you!
Thank-you!
Qwiic on WIFI R4 is Wire1. Make sure to use Wire1 instead of Wire.
Change
Wire.begin();
if (mySensor.beginI2C() == false) //Begin communication over I2C
Serial.println(“The sensor did not respond. Please check wiring.”);
while(1); //Freeze
change to :
Wire1.begin();
if (mySensor.beginI2C(Wire1) == false) //Begin communication over I2C
while(1); //Freeze
Thank-you, that was the problem.
