Razor IMU - I2C & sensor problem
Hi everyone,
i have a seriuos problem with my SEN-10736 - 9 Degrees of Freedom - Razor IMU. i try to upload some kind on firmware without any change.
i connect my card with simple FDTI basic nothing else.
Razor Imu don’t comunicate with sensor. the output of serial is:
ITG: BAD
HMC: BAD
ADXL: BAD
9DOF IMU Firmware v23
[1]Accelerometer: ADXL345
[2]Magnetometer: HMC5883
[3]Gyroscope: ITG-3200
[4]Raw Output
[5]Change Baud Rate: 57600bps
[Ctrl+z]Toggle Autorun
[?]Help
I think that the problem is in I2C connection with the sensor but i don’t sure of that.
Any Suggestion?
Sorry for my bad english.
Thanks for every kind of help.
Regards,
Riccardo
Hi Riccardo,
I’ve the same problem, and when I try to upload the code receive this error:
avrdude: Version 6.0.1, compiled on Oct 21 2013 at 15:55:32
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is “/usr/share/arduino/hardware/tools/avrdude.conf”
User configuration file is “/home/raffaello/.avrduderc”
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [00]
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Finally if I open the “serial monitor” on Arduino I receive your output, but if I try to send a number the Razor doesn’t receive anything!
Any Suggestion?
