I just got a new Razor IMU. I think when I plug it into my computer I should see a USB serial port show up, but I don’t see anything. I’m on macOS Catalina, have the FTDI drivers installed, using a USB cable I know isn’t broken. The blue LED on the Razor blinks after it’s been plugged in.
I don’t see any ports show up in /dev/tty.* or even anything in ioreg when I plug in the Razor. Confirmed that I can get a FT232 to work fine.
Is there a driver I need to install? Anything I need to get to get the Razor to work out of the box as is described in the hookup guide?
