Redboard ATP serial ports
I’m attempting to use the second UART (TX1/RX1) on the Redboard ATP with some Arduino libraries (Robertsonic’s library for the WAV trigger sold by Sparkfun). I know the library is probably not compatible with the Apollo, but I was hoping to borrow the basic serial messaging code from it.
I’m getting compilation errors of:
'Serial1' was not declared in this scope
Do I need to configure the UART before use and if so, how?
Check out this pull request, which includes some sample code using TX1/RX1. It works, at least in the v1.2.0 version of the core.
https://github.com/sparkfun/Arduino_Apollo3/pull/144
Sorry I didn’t get a notification of your reply - much appreciated! I’ll check that out!
