I am new to openocd and need your kind help.
I copied some code from distributed scripts and got it was trying to get
it run with my board which is based on samsung s3c2416 (arm926ejs) and
has a 2x5pin jtag interface connected to my j-link adaptor.
After successed with some basic initialization, I tried issue 'reset
halt’ from telnet port, but it failed with some errors:
WARNING: mystery debug reason MOE = 0xc. Try issuing a resume + halt.
invalid mode value encountered 8
Jazelle state handling is BROKEN!
cpsr contains invalid mode value - communication failure
I don’t understand what really happened and what’s the error exactly. So
I am attaching the openocd log output and my script file to this email.
Hope someone can give me an idea.
Thanks in advance!
– The Log —
Info : 269 8523 server.c:83 add_connection(): accepting ‘telnet’ connection from 4444
Debug: 270 12114 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_reset halt
Debug: 271 12114 command.c:145 script_debug(): command - reset ocd_reset halt
Debug: 273 12135 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_target names
Debug: 274 12135 command.c:145 script_debug(): command - ocd_target ocd_target names
Debug: 275 12135 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu invoke-event reset-start
Debug: 276 12135 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu invoke-event reset-start
Debug: 277 12135 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init-reset
Debug: 278 12135 command.c:145 script_debug(): command - ocd_jtag ocd_jtag arp_init-reset
Debug: 279 12135 core.c:1520 jtag_init_reset(): Initializing with hard TRST+SRST reset
Debug: 280 12135 jlink.c:667 jlink_reset(): trst: 1, srst: 0
Debug: 281 12137 core.c:738 jtag_add_reset(): TRST line asserted
Debug: 282 12137 jlink.c:667 jlink_reset(): trst: 1, srst: 1
Debug: 283 12139 core.c:715 jtag_add_reset(): SRST line asserted
Debug: 284 12139 jlink.c:667 jlink_reset(): trst: 0, srst: 1
Debug: 285 12141 core.c:743 jtag_add_reset(): TRST line released
Debug: 286 12141 core.c:323 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 287 12141 jlink.c:667 jlink_reset(): trst: 0, srst: 0
Debug: 288 12143 core.c:719 jtag_add_reset(): SRST line released
Debug: 289 12143 core.c:1412 jtag_init_inner(): Init JTAG chain
Debug: 290 12143 core.c:323 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 291 12146 core.c:1048 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS
Debug: 292 12146 core.c:323 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 293 12281 core.c:951 jtag_examine_chain_display(): JTAG tap: s3c2416.cpu tap/device found: 0x07926f0f (mfg: 0x787, part: 0x7926, ver: 0x0)
Debug: 294 12281 core.c:1208 jtag_validate_ircapture(): IR capture validation scan
Debug: 295 12286 core.c:1267 jtag_validate_ircapture(): s3c2416.cpu: IR capture 0x01
Debug: 296 12286 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu cget -chain-position
Debug: 297 12286 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu cget -chain-position
Debug: 298 12286 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled s3c2416.cpu
Debug: 299 12286 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled s3c2416.cpu
Debug: 300 12286 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu invoke-event examine-start
Debug: 301 12286 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu invoke-event examine-start
Debug: 302 12286 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu arp_examine
Debug: 303 12286 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu arp_examine
Debug: 304 12314 embeddedice.c:501 embeddedice_write_reg(): 0: 0x00000000
Debug: 305 12325 arm7_9_common.c:75 arm7_9_clear_watchpoints(): -
Debug: 306 12325 embeddedice.c:501 embeddedice_write_reg(): 12: 0x00000000
Debug: 307 12325 embeddedice.c:501 embeddedice_write_reg(): 20: 0x00000000
Debug: 308 12345 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu invoke-event examine-end
Debug: 309 12345 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu invoke-event examine-end
Debug: 310 12345 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu invoke-event reset-assert-pre
Debug: 311 12345 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu invoke-event reset-assert-pre
Debug: 312 12345 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu cget -chain-position
Debug: 313 12345 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu cget -chain-position
Debug: 314 12345 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled s3c2416.cpu
Debug: 315 12345 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled s3c2416.cpu
Debug: 316 12345 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu arp_reset assert 1
Debug: 317 12346 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu arp_reset assert 1
Debug: 318 12346 target.c:1620 target_free_all_working_areas_restore(): freeing all working areas
Debug: 319 12346 arm7_9_common.c:878 arm7_9_assert_reset(): target->state: running
Debug: 320 12346 embeddedice.c:501 embeddedice_write_reg(): 2: 0x00000001
Debug: 321 12357 jlink.c:667 jlink_reset(): trst: 0, srst: 1
Debug: 322 12359 core.c:715 jtag_add_reset(): SRST line asserted
Debug: 323 12359 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu invoke-event reset-assert-post
Debug: 324 12359 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu invoke-event reset-assert-post
Debug: 325 12359 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu invoke-event reset-deassert-pre
Debug: 326 12359 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu invoke-event reset-deassert-pre
Debug: 327 12359 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu cget -chain-position
Debug: 328 12359 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu cget -chain-position
Debug: 329 12359 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled s3c2416.cpu
Debug: 330 12359 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled s3c2416.cpu
Debug: 331 12359 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_s3c2416.cpu arp_reset deassert 1
Debug: 332 12359 command.c:145 script_debug(): command - ocd_s3c2416.cpu ocd_s3c2416.cpu arp_reset deassert 1
Debug: 333 12359 target.c:1620 target_free_all_working_areas_restore(): freeing all working areas
Debug: 334 12359 arm7_9_common.c:973 arm7_9_deassert_reset(): target->state: reset
Debug: 335 12410 jlink.c:667 jlink_reset(): trst: 0, srst: 0
Debug: 336 12413 core.c:719 jtag_add_reset(): SRST line released
Debug: 337 12433 embeddedice.c:501 embeddedice_write_reg(): 0: 0x0000000f
Debug: 338 12444 arm7_9_common.c:75 arm7_9_clear_watchpoints(): -
Debug: 339 12444 embeddedice.c:501 embeddedice_write_reg(): 12: 0x00000000
Debug: 340 12444 embeddedice.c:501 embeddedice_write_reg(): 20: 0x00000000
Debug: 341 12484 embeddedice.c:501 embeddedice_write_reg(): 0: 0x0000000d
Debug: 342 12484 embeddedice.c:501 embeddedice_write_reg(): 0: 0x0000000d
Warn : 343 12524 arm926ejs.c:306 arm926ejs_examine_debug_reason(): WARNING: mystery debug reason MOE = 0xc. Try issuing a resume + halt.
Debug: 344 12524 arm7_9_common.c:1290 arm7_9_debug_entry(): target entered debug from ARM state
Error: 345 12973 armv4_5.c:189 arm_mode_to_number(): invalid mode value encountered 8
Error: 346 12973 armv4_5.c:386 arm_set_cpsr(): Jazelle state handling is BROKEN!
Debug: 347 12973 armv4_5.c:395 arm_set_cpsr(): set CPSR 0xffff9988: User mode, Jazelle state
Error: 348 12973 arm7_9_common.c:1313 arm7_9_debug_entry(): cpsr contains invalid mode value - communication failure
User : 349 12973 command.c:549 command_print():
Debug: 350 12973 command.c:631 run_command(): Command failed with error code -4
User : 351 12973 command.c:669 command_run_line(): in procedure ‘reset’
— My Script —
gdb_port
tcl_port
telnet_port
echo “— adaptor config —”
source [find interface/jlink.cfg]
adapter_khz 5
echo “— chip config —”
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME s3c2416
if { [info exists ENDIAN] } {
set _ENDIAN $ENDIAN
} else {
this defaults to a bigendian
set _ENDIAN little
if { [info exists CPUTAPID] } {
set _CPUTAPID $CPUTAPID
} else {
set _CPUTAPID 0x07926f0f
#jtag scan chain
jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x01 -irmask 0x0f -expected-id $_CPUTAPID
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME arm926ejs -endian $_ENDIAN -chain-position $_TARGETNAME -variant arm926ejs
echo “— board config —”
reset_config trst_and_srst separate
$_TARGETNAME configure -event reset-init { tq2410_init }
proc tq2410_init { } {
echo “reset-init”
-woody
