Restoring the on-board root filesystem
Hi , I’ve extracted and copied on an ext3 USB flash drive the root filesystem archive provided on the olimex cd and the .img file and I’ve started correctly the board .
When I try with the command:
flash_eraseall -j /dev/mtd1
I get this message:
sam9-l9260:/# flash_eraseall -j /dev/mtd1
bash: flash_eraseall: command not found
And if Itry :
modprobe mtdchar
I get:
sam9-l9260:/# modprobe mtdchar
FATAL: Could not load /lib/modules/2.6.23/modules.dep: No such file or directory
but in the archive provided by OLIMEX’s cd there isn’t anything in the /lib/modules/2.6.23/
directory.
Please , can somebody tell me how to fix this problem?
Thank you very much.
Problem fixed (thanks to olimex support team) with the command :
/usr/sbin/flash_eraseall -j /dev/mtd1
:smiley:
