RPi 4B to replace 3B does not boot
i just purchased a RPi 4B 4GB. I pulled the microSD card from my 3B model and the kbrd/mouse.
the only difference was the new 4B needed a micro HDMI cable.
The new 4B does not boot or at least does not show anything on monitor. The red LED and green LED do light up.
Did I make a bad presumption that i can boot & run the newer model with the SD card i’m using in the 3B model?
Does each RPi have to be config’d with a new NOOBS init SD card?
Usually when a new Pi comes out, there are enough changes to the hardware that an old card won’t work in a new Pi.
You probably need to update the card in your old Pi first.
Generally running the commands below on the old Pi first will take care of the update but you will need internet access on your Pi to run them.
sudo apt-get update
sudo apt-get upgrade
If those fail to get your card to boot on the new Pi, you might need to grab the latest version of NOOBS and give that a try on a formatted SD card. The latest version that works with the Pi4 is at the link below.
  • https://downloads.raspberrypi.org/NOOBS_latest
  • Had also the problem that my raspbian card from pi3 did not run in pi4 after upgrade to buster.
    I found out that the install skript of bootloader and kernel do skip the installation of rpi4 support when there is not enough space on /boot/. My boot partition was around 100 Mb, its from the time when rpi2 was new. You can check the size of your partition with:
    df -H
    or
    mount
    you can also check if the install skript says you havn’t enough space by reinstalling and checking the output of:
    apt-get install --reinstall raspberrypi-bootloader* raspberrypi-kernel*
    if you see the following output, you have the same Problem:
    You do not have enough space in /boot to install this package.
    Skipping Pi 4 support
    To solve this problem i used a separate computer and changed the size of the /boot partition to at least 500Mb (usual size on other Linux) by the following steps. (assuming first partition is boot, second is root, using gparted for partion manipulation)
    Backup whole SD
    shrinking root Partition to the right to have free space for boot
    copy content of boot partition to separate backupfolder
    remember boot partition flags
    delete and recreate boot partiton with the same filesystem in free space
    set the partition flag from point 4
    copy content of backupfolder (see point 3) into boot partion folder
    check your /etc/fstab is still valid to boot (more to this following)
    boot sdcard in rpi3 and reinstall “raspberrypi-bootloader* raspberrypi- kernel*”
    boot sd in rpi4
    my /etc/fstab did not reference /boot by uuid, if your fstab file has a entry like:
    UUID=2e45-11ea /boot vfat defaults,noatime 0 2
    you need to change the uuid to the new uuid of the new boot partition. You can find the uuid in gparted under information. i had no problem with my /etc/fstab, it has this entry:
    /dev/mmcblk0p1 /boot vfat defaults,noatime 0 2
