RPi A111 Radar: problem getting started
I installed and built acconeer_rpi_sparkfun_v2_4_0.zip without a problem.
When trying the examples I git a problem with gpio that I have not been able to sort out:
~/rpi_sparkfun/out $ sudo ./example_assembly_test_rpi_sparkfun_a111_r2c
00:06:24.611 [ 1032] (E) (driver_gpio_linux_sysfs) Could not write to gpio export: Device or resource busy
00:06:24.612 [ 1032] (E) (driver_gpio_linux_sysfs) Could not write to gpio export: Device or resource busy
Any advice?
Do you have any background programs running that are trying to use the GPIO pins? You can run a top to check what all is running in the foreground and background.
Not that I can see, but I am not quite sure about exactly which ones to suspect.
Here is the list
Tanks a lot for responding!
iB Swap: 100,0 total, 98,5 free, 1,5 used. 276,4 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3933 sa0bxi 20 0 13196 3280 2740 R 1,0 0,7 0:00.11 top
9 root 20 0 0 0 0 S 0,3 0,0 0:05.05 ksoftirqd/0
369 root 20 0 27656 1452 1324 S 0,3 0,3 0:34.81 rngd
540 root 20 0 51024 15308 8532 S 0,3 3,5 1:32.57 fail2ban-server
3132 sa0bxi 20 0 12236 3868 3080 S 0,3 0,9 0:00.57 sshd
3929 root 20 0 0 0 0 I 0,3 0,0 0:00.03 kworker/u8:3-events_unbound
1 root 20 0 33736 8016 6412 S 0,0 1,8 0:09.72 systemd
2 root 20 0 0 0 0 S 0,0 0,0 0:00.18 kthreadd
3 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 rcu_gp
4 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 rcu_par_gp
8 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 mm_percpu_wq
10 root 20 0 0 0 0 I 0,0 0,0 0:08.53 rcu_sched
11 root rt 0 0 0 0 S 0,0 0,0 0:00.04 migration/0
12 root 20 0 0 0 0 S 0,0 0,0 0:00.00 cpuhp/0
13 root 20 0 0 0 0 S 0,0 0,0 0:00.00 cpuhp/1
14 root rt 0 0 0 0 S 0,0 0,0 0:00.03 migration/1
15 root 20 0 0 0 0 S 0,0 0,0 0:00.12 ksoftirqd/1
18 root 20 0 0 0 0 S 0,0 0,0 0:00.00 cpuhp/2
19 root rt 0 0 0 0 S 0,0 0,0 0:00.03 migration/2
20 root 20 0 0 0 0 S 0,0 0,0 0:00.10 ksoftirqd/2
23 root 20 0 0 0 0 S 0,0 0,0 0:00.00 cpuhp/3
24 root rt 0 0 0 0 S 0,0 0,0 0:00.03 migration/3
25 root 20 0 0 0 0 S 0,0 0,0 0:00.19 ksoftirqd/3
28 root 20 0 0 0 0 S 0,0 0,0 0:00.00 kdevtmpfs
29 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 netns
32 root 20 0 0 0 0 S 0,0 0,0 0:00.22 khungtaskd
33 root 20 0 0 0 0 S 0,0 0,0 0:00.00 oom_reaper
34 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 writeback
35 root 20 0 0 0 0 S 0,0 0,0 0:00.00 kcompactd0
52 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 kblockd
53 root rt 0 0 0 0 S 0,0 0,0 0:00.00 watchdogd
56 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 rpciod
57 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 kworker/u9:0-hci0
58 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 xprtiod
59 root 20 0 0 0 0 S 0,0 0,0 0:00.91 kswapd0
60 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 nfsiod
61 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 iscsi_eh
62 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 dwc_otg
63 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 DWC Notificatio
65 root 1 -19 0 0 0 S 0,0 0,0 0:00.00 vchiq-slot/0
66 root 1 -19 0 0 0 S 0,0 0,0 0:00.00 vchiq-recy/0
67 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 vchiq-sync/0
68 root 20 0 0 0 0 S 0,0 0,0 0:00.00 vchiq-keep/0
69 root 10 -10 0 0 0 S 0,0 0,0 0:00.00 SMIO
72 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 mmc_complete
74 root 0 -20 0 0 0 I 0,0 0,0 0:00.35 kworker/3:1H-kblockd
75 root 20 0 0 0 0 S 0,0 0,0 0:00.13 jbd2/mmcblk0p2-
76 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 ext4-rsv-conver
78 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 ipv6_addrconf
83 root 0 -20 0 0 0 I 0,0 0,0 0:00.18 kworker/1:1H-kblockd
85 root 0 -20 0 0 0 I 0,0 0,0 0:00.16 kworker/2:1H-kblockd
95 root 0 -20 0 0 0 I 0,0 0,0 0:00.57 kworker/0:2H-kblockd
122 root 20 0 26776 7784 6900 S 0,0 1,8 0:02.18 systemd-journal
141 root 20 0 18272 4012 3116 S 0,0 0,9 0:01.70 systemd-udevd
160 root 10 -10 0 0 0 S 0,0 0,0 0:00.00 SMIO
165 root 20 0 0 0 0 S 0,0 0,0 0:00.00 spi0
167 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 mmal-vchiq
169 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 mmal-vchiq
170 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 mmal-vchiq
173 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 mmal-vchiq
222 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 cfg80211
227 root 0 -20 0 0 0 I 0,0 0,0 0:00.00 brcmf_wq/mmc1:0
228 root 20 0 0 0 0 S 0,0 0,0 0:11.48 brcmf_wdog/mmc1
302 systemd+ 20 0 22412 5652 5000 S 0,0 1,3 0:01.11 systemd-timesyn
346 message+ 20 0 6548 3520 3036 S 0,0 0,8 0:00.70 dbus-daemon
347 nobody 20 0 4320 2020 1848 S 0,0 0,5 0:02.16 thd
350 avahi 20 0 5904 2992 2608 S 0,0 0,7 0:27.56 avahi-daemon
I should say that I am using a fresh raspbian buster lite install, so whatever is blocking should not be my doing, as far as I understand…
And you’ve enabled SPI in raspi-config? https://learn.sparkfun.com/tutorials/ge … re-your-pi
yes, SPI is enabled, while i2c and onewire are disabled.
For security reasons, I do use another user than pi. could that be a problem?
Sorry to have bothered you. I started all over, stayed with user pi, installed nothing else, and now it works. Thanks for making me focus on basics.
No worries, that can be the most infuriating thing about Raspberry Pi. Small details!
Hi, you mean you could run it under Stretch?
Im curretly facing same isuues, I have PI4- neither Buster + Desktop oder Buster Lite have solved,
still (E) (driver_gpio_linux_sysfs) Could not write to gpio export: Device or resource busy
Idk why SPI gets busy by anything even under Lite
Are u guys using another versions of Pi, 3,3B ?
I have had no issues using (from cat /proc/cpuinfo):
Hardware : BCM2835
Revision : a020d3
Serial : 00000000ab78959a
Model : Raspberry Pi 3 Model B Plus Rev 1.3
running (lsb_release -a):
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
I am having the same error when I am trying to run any executable example in the /out folder. I do not have anything else running at the same time. The error is
[ 4460] (E) (driver_gpio_linux_sysfs) Could not write to gpio export: Device or resource busy
I followed the instructions on [Sparkfun A111 Guide][/https://learn.sparkfun.com/tutorials/ge … dar-sensor]. Everything went smooth till the time I try running example.
Here is cat /proc/cpuinfo
Hardware : BCM2711
Revision : b03111
Serial : 10000000ce567916
Model : Raspberry Pi 4 Model B Rev 1.1
Here is lsb_release-a
Release: 10
Codename: buster
Any help would be appreciated.
Hello people,
I get the same issue, the following user suggested this solution:
sa0bxi:
Unfortunately it does not work for me. The sole user on my Raspberry 4 model b is the default one (pi).
I am using the recommanded raspberry Pi OS, with the Desktop.
my top:
542 root 20 0 243164 81936 42640 S 6.6 2.1 0:13.70 Xorg
1288 pi 20 0 438408 134856 84932 S 6.6 3.4 1:05.35 chromium-browse
860 pi 20 0 237956 50392 37684 S 4.3 1.3 0:01.74 lxterminal
1062 pi 20 0 405340 108076 86716 S 4.0 2.8 0:30.23 chromium-browse
1468 pi 20 0 10436 3148 2508 R 0.7 0.1 0:00.08 top
409 nobody 20 0 4320 2148 1976 S 0.3 0.1 0:00.49 thd
1017 pi 20 0 453956 119252 83900 S 0.3 3.0 0:27.94 chromium-browse
1377 pi 20 0 329660 78996 60072 S 0.3 2.0 0:03.11 chromium-browse
1 root 20 0 33616 8028 6476 S 0.0 0.2 0:03.71 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.01 kthreadd
3 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_gp
4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_par_gp
6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-mmc_complete
7 root 20 0 0 0 0 I 0.0 0.0 0:00.47 kworker/u8:0-brcmf_wq/mmc1:0001:1
8 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mm_percpu_wq
9 root 20 0 0 0 0 S 0.0 0.0 0:00.21 ksoftirqd/0
10 root 20 0 0 0 0 I 0.0 0.0 0:00.17 rcu_sched
11 root rt 0 0 0 0 S 0.0 0.0 0:00.01 migration/0
12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0
13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1
14 root rt 0 0 0 0 S 0.0 0.0 0:00.01 migration/1
15 root 20 0 0 0 0 S 0.0 0.0 0:00.06 ksoftirqd/1
18 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/2
19 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/2
20 root 20 0 0 0 0 S 0.0 0.0 0:00.08 ksoftirqd/2
21 root 20 0 0 0 0 I 0.0 0.0 0:00.00 kworker/2:0-mm_percpu_wq
23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/3
24 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/3
25 root 20 0 0 0 0 S 0.0 0.0 0:00.08 ksoftirqd/3
28 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs
29 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 netns
30 root 20 0 0 0 0 I 0.0 0.0 0:00.05 kworker/0:1-mm_percpu_wq
32 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khungtaskd
33 root 20 0 0 0 0 S 0.0 0.0 0:00.00 oom_reaper
34 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 writeback
35 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kcompactd0
52 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kblockd
53 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 blkcg_punt_bio
56 root rt 0 0 0 0 S 0.0 0.0 0:00.00 watchdogd
57 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rpciod
59 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 xprtiod
60 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kswapd0
61 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 nfsiod
62 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kthrotld
63 root -51 0 0 0 0 S 0.0 0.0 0:00.00 irq/54-aerdrv
64 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 iscsi_eh
67 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 DWC Notificatio
68 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 uas
70 root 1 -19 0 0 0 S 0.0 0.0 0:00.00 vchiq-slot/0
71 root 1 -19 0 0 0 S 0.0 0.0 0:00.00 vchiq-recy/0
72 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 vchiq-sync/0
73 root 20 0 0 0 0 S 0.0 0.0 0:00.00 vchiq-keep/0
74 root 10 -10 0 0 0 S 0.0 0.0 0:00.00 SMIO
76 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 sdhci
77 root -51 0 0 0 0 S 0.0 0.0 0:00.00 irq/41-mmc0
78 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mmc_complete
82 root 20 0 0 0 0 S 0.0 0.0 0:00.06 jbd2/mmcblk0p2-
83 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 ext4-rsv-conver
85 root 0 -20 0 0 0 I 0.0 0.0 0:00.18 kworker/1:2H-kblockd
86 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 ipv6_addrconf
90 root 0 -20 0 0 0 I 0.0 0.0 0:00.28 kworker/2:1H-kblockd
my config.txt:
For more options and information see
http://rpf.io/configtxt
Some settings may impact device functionality. See link above for details
uncomment if you get no picture on HDMI for a default “safe” mode
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
disable_overscan=1
uncomment the following to adjust overscan. Use positive numbers if console
goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
uncomment to force a console size. By default it will be display’s size minus
overscan.
#framebuffer_width=1280
#framebuffer_height=720
uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
uncomment to force a HDMI mode rather than DVI. This can make audio work in
DMT (computer monitor) modes
#hdmi_drive=2
uncomment to increase signal to HDMI, if you have interference, blanking, or
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
Additional overlays and parameters are documented /boot/overlays/README
Enable audio (loads snd_bcm2835)
#dtparam=audio=on
[pi4]
Enable DRM VC4 V3D driver on top of the dispmanx display stack
#dtoverlay=vc4-fkms-v3d
#max_framebuffers=2
[all]
thanks for the help and any inputs you could provide me.
Hi guys!
we have tried here at work some workarounds till now without success.
firstly we have check SPI connetion with another sensor and it works as usuall, raspi4 seems to be working fine.
making sure nothing else working in backfround, under Busterlite showed some message: [ 1032] (E) (driver_gpio_linux_sysfs) Could not write to gpio export: Device or resource busy
in somehow this issues persists,
we wanted to get several of them for implementation, we just dont know how to go any further
any kind of help would be very welcome, we want to keep our hopes in this device…
all best, Regards
Nicolas
Solved using the buster Debian instead of the easy-to-use install.
Great! thanks hdelon!
im gonna try right now, btw wihch version did you use, 10.5 ?
Hi guys!
I have solved by usung a short configuration for the Acconer XC112 , as explain in the README_rpi.pdf in docs folder (in SDK).
Start a terminal window and type “sudo raspi-config” - In Localisation Options,
select the appropriate timezone. - In Interfacing Options, enable SPI and I2C
and the SSH interfaces.
If you plan to use XC112 with newer kernels (v5.4 and later) the following line
must be added to /boot/config.txt (i.e. sudo nano /boot/config.txt) and then
reboot.
dtoverlay=spi0-cs,cs0_pin=8,cs1_pin=28
The reason for this is that the kernel spi driver controls and prevent any user
application from controlling the SPI0 CS1 which is by default mapped to GPIO7.
The above line will remap SPI0 CS1 to GPIO28 (which is a pin not available on
the Raspberry Pi header) and release the GPIO7 so that it can be controlled by
the Acconeer SW.
important to reboot after saving the config.txt
I hope this helps many of you :wink:
I am getting a similar error to what other posts show:
00:01:49.357 [ 950] (E) (driver_gpio_linux_sysfs) Could not write to gpio export: Device or resource busy
I did make the change to /boot/config.txt as noted above, no help.
Running sudo cat /sys/kernel/debug/gpio gives me:
gpiochip0: GPIOs 0-53, parent: platform/3f200000.gpio, pinctrl-bcm2835:
gpio-4 ( |onewire@0 ) out lo
gpio-8 ( |spi0 CS0 ) out hi ACTIVE LOW
gpio-28 ( |spi0 CS1 ) out hi ACTIVE LOW
gpiochip1: GPIOs 100-101, brcmvirt-gpio, can sleep:
gpio-100 ( |led0 ) out hi
gpiochip2: GPIOs 504-511, parent: platform/soc:firmware:expgpio, raspberrypi-exp-gpio, can sleep:
gpio-511 ( |led1 ) in hi
I am running Debian Buster v10 (not sure what sub-version nor how to find it).
I do have SPI and I2C enabled. The only things connected are the A111 breakout board, HDMI for video and USB for KB/Mouse. Running my tests through a terminal window on the desktop.
Running on Rpi 3 B.
Any help would be greatly appreciated
