I have three different main profiles I use on my RTK Express. Obviously, I know there is a way to change profiles, but when I am in the field, is there a way to see which profile is currently active?
Unfortunately there is not a good way via the display, at this time, to see which profile is in use. One solution would be to connect over Bluetooth and view the selected profile via serial config, but I realize this is a bit of extra work. Alternatively, there is no harm in loading the profile you want to use, even if that profile may be already running.
