Recently I had bought RTK Express Kit and RTK Express Plus Kit.
RTK Express is working properly but unfortunately, RTK Express Plus got a few problems.
- LED charging indicator light up event no charging cable attached.
 The LED indicator is less brightness while not charging compared to while charging the RTK.
 1st picture is not charging. 2nd picture is in charging mode.
- RTK Express Plus does not pick up any satellite.
 At first, I hook up the device with the Lora Serial, but there has no satellite locked. Then I try connecting directly the RTK Express Plus to antenna, but still not lock any satellite. I can confirm the cable and antenna in good condition because already test with the RTK Express.
 1st picture show RTK Express. 2nd picture show RTK Express Plus.
- Cannot connect to RTK Express Plus BLE.
 After pairing, not connected to BLE. Only saved on smartphone setting.
- No output power on antenna connector.
 Tried with multimeter but no voltage at the connector. The connector seems properly soldered to the board.
For information, I have done the factory reset but the error still occurred.
Hope to get your advice soon.
Thank you.
