I just ordered an RTK facet and I’m excited to put it to use! Initially, I’ll only use one and my cellphone as an RTK rover, but eventually I’ll buy a second one for use as a rover receiving RTK updates from the base. But when using a unit as a rover, if I’m using it to mark a point on the ground, how would I go about establishing a height offset? Is that something I would do in software based on the measurement of the pole? Or is that a setting that can be changed in the unit?
Thank you!
