RTK Surveyor 100 cm LED Only
I just purchased a new RTK Surveyor Kit. Out of the box only the 100cm LED will come on. I am using SW Maps and have data coming in. Ntrip is setup and seems to be getting data according to display on my phone. I am using RTK2GO. I am running the latest firmware.
What antenna are you using?
the antenna that came with the kit. Top106
Are you indoors while using the kit or outside with a clear view of the sky? (No trees or other buildings around)
I was outside. Issue was with Ntrip. Working as it should. Thanks
