No NTRIP streaming to RTK Surveyor
I am new, read a lot, but cannot get RTK Surveyor closer than 100cm accuracy. Using SW Maps with NTRIP Connection and tried GNSS Surveyor with NTRIP addon. Bluetooth is working. In an open field with antenna hooked up. I think there is a button I am missing but after hours of looking on Ubox and throught tutorials I cannot find the missing setting.
Devices tried with RTK Surveyor
Samsung S21
Kyocera phone
Samsung tablet
100cm or 100mm? Either way, there’s something afoot.
A you seeing RTK float? The bubble in SW Maps should turn blue (I think) indicating float. You can also view in GNSS Status. Additionally during RTK float, you should see the white RTK LED on the RTK surveyor start to blink
How far is the RTCM correction location from your location? Baselines need to be <20km or so, but even then you should get RTK float.
Be sure the internal switches are both in the upwards position as shown below:
https://user-images.githubusercontent.c … 4bbe8e.png
I have tried with the same NTRIP provider and got the same result. As you can observe from the image that you posted no data is received by the rover (0B/s). Maybe the GPS also has to be connected to the internet or some hot spot. Try changing the NTRIP provider and see if you get the same results
100cm is the only light coming on.
I will try to open the receiver box and see where the switches are at.
I have found a close station, but not sure how to hook it up.
Not getting any float at all.
Both switches are up. No float RTK.
